03-07-2013, 03:29 PM | #1 |
Drives: 2011 2SS Join Date: Sep 2011
Eibach Multi Pro users, looking for pics.
03-08-2013, 12:02 AM | #2 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
03-09-2013, 09:46 AM | #3 |
No, I don't work for Eibach.
Anyone? |
03-09-2013, 10:49 AM | #4 |
Drives: 11 Seconds or Faster Join Date: May 2012
I have some pics. Ride height is crazy low because of the iron block up front. You know you've got a beast motor when you need new springs
03-09-2013, 11:19 AM | #5 |
With your setup I would run 300lb or 325lb front spring and you can run 600lbs or 650lbs R spring. That's what I had on my R1s. The stock 225F and 450R is way too soft. My car actually rolled more with the stock R1s vs stock suspension with BMR 1" springs.
03-09-2013, 01:35 PM | #6 |
For AutoX or circuit I would run that stiff of a spring, but I will need a setup for the fastest weight transfer possible for the strip. So I think for now I'll go to a 350 up front and stick with the 450 for the rear.
03-09-2013, 10:23 PM | #7 |
2SS, do you really drive it that low??? What's the measurement from the lip of the rim to the fender? I'm going to guess ~25 inches.
I've got a Maggie too and I'm running a 325# spring up front and 475 rear. I'm thinking about going to a 500 or 525 in the back; 600+ seems awfully stiff. Anyone else have any pics of Eibach coilovers installed? |
03-10-2013, 11:39 AM | #8 |
No I don't drive it like that, but I don't have to worry about driving it either. I trailer is to the strip and back, not really a street car anymore. I think there are very few of us running the multipro R2
03-10-2013, 03:22 PM | #9 | |
03-10-2013, 03:36 PM | #10 |
Could very well be, maybe with the external reservoirs it helps keep it together a bit more, who knows.
03-11-2013, 02:17 PM | #11 | |
We are talking about the street here. On the street, I'm finding the 475 in the back might be a little soft, but not by much. I'm just getting started getting them dialed. Why didn't you have the R1's re-valved? |
03-12-2013, 01:43 AM | #12 | |
