Old 03-14-2013, 11:31 PM   #1
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
How often do you change spark plugs on cammed engine?
Im wondering how often others change out their spark plugs.
it seems like I have to change them out every 2-3 months, due to fouling.
anyone else?
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is online now   Reply With Quote
Old 03-14-2013, 11:38 PM   #2
Chevrolade
Drives: 2010 2SS/RS
What plugs are u running ? I run tr5 and they last a good while.
Chevrolade is offline   Reply With Quote
Old 03-15-2013, 07:04 AM   #3
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
anyone else?
that dont sound right to me but we need more info like what plugs, cam anything would help
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ
APPEARANCE
COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING
biggerisbetter is offline   Reply With Quote
Old 03-15-2013, 07:16 AM   #4
Scott@Bjorn3D
Do you have a catch can? You could have a bad valley cover and pulling allot of oil in thru the intake side fouling the plugs.
Scott@Bjorn3D is offline   Reply With Quote
Old 03-15-2013, 07:26 AM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Rich tune?
What sparkplugs?
What gap?
What cam?
What's your complete set up?
Old 03-15-2013, 08:10 AM   #6
nighttowl
nighttowl's Avatar
vvt-2 cam: duration / lift: 277 Intake .615 lift 285 Exhaust .620 lift - yello terra roller rocker arms - 25% under drive pulley - GMPP CNC ported heads - vararam tune model - Yank 3200 stall converter - vmax ported throttle body - 1 7/8 long tubes w/ high flow cats - full 3" exhaust
im running the stock plugs, because:
Originally Posted by JANNETTYRACING View Post
No better plug than the factory plugs.
Ted.
they are not oil fouled, when I pull the plugs there is no carbon (burned oil), its fuel soaked I believe.
I think I need a different heat range to bake it off, or maybe more juice (upgraded coil packs)?
Does MSD make a multiple spark discharge (CD) unit for this car?
The stock ignition may do it on its own, I don't know.
I tried a standard resistor plug a while back, but the coils ate them up in a about 2 weeks.
My Dual wideband setup says its stoichiometric while running and idling, which is most of its duty. I do not get on it very often, I live in the city. I do not suspect the tune.
maybe CA's crappy 91 octane gas is the culprit?
im running torco, ending up at about 95 octane.
Just changing plugs usually feels like I'm adding 50hp after a couple months.
Old 03-15-2013, 08:14 AM   #7
Alvin@PCMofNC
Drives: 2010 IOM RSS
NGK copper plugs every 15k miles as long as the tune is in good shape. I've ran NGK iridium and Denso iridium to 30-35k miles with no problems. The stock plug heat range is too hot for most modded engines. For a good how to on reading plugs check out this tech article I wrote a few years back.
http://www.pcmofnc.com/index.php/blo...ad-spark-plugs
Alvin@PCMofNC is offline   Reply With Quote
Old 03-15-2013, 08:39 AM   #8
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Negative DO NOT USE MSD's they are a waste of money and pointless!
It's your tune, it's too rich. I'd go back to your tuner and get it checked out. Who tuned it?
Old 03-15-2013, 08:58 AM   #9
429
Br7efs every 8-10k as needed
429 is offline   Reply With Quote
Old 03-15-2013, 09:02 AM   #10
biggerisbetter
lll
from his previous post it looks like he has a jannetty tune
PERFORMANCE
APPEARANCE
Old 03-15-2013, 09:07 AM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Wow a mail order tune with a cam?= no bueno.
Cunningham Motorsports for the win!!
Sdcpa? Is his screen name and he laid down some good numbers over there.
Old 03-15-2013, 09:09 AM   #12
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
Stock plugs are way too hot for most cammed applications.. just as Alvin said.
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 03-15-2013, 09:34 AM   #13
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
What plug do you recomend, part number please! Time to change my stockers it sounds like.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 03-15-2013, 09:44 AM   #14
nighttowl
nighttowl's Avatar
It was Dyno tuned by superior auto in placentia.
