Old 03-18-2013, 08:16 PM   #1
Deathmore
Drives: None Yet
Can I put these on all four corners? 285/50ZR18
Hi everyone I want to put these Pirelli Scorpion Zero Asimmetrico tires on all four corners of my Camaro. They are 285/50ZR18(looking to add some serious durability to my car). My question is can it be done without any mods? I originally wanted o put 255/55R18 up front but the speed rating for them was only 130mph VS 168mph on the bigger ones. Will I run into any problems with them being the same size.
Link to Tires:
http://www.tirerack.com/tires/tires....OR0A&tab=Specs
Deathmore is offline   Reply With Quote
Old 03-18-2013, 09:22 PM   #2
SparkyDL75
SparkyDL75
SparkyDL75's Avatar
Drives: 2010 Camaro 2SS/RS CGM/Grey
Other than the fact that Pirelli Scorpion tires are designed for pickup trucks and suvs..... I am going to go out on a limb and bet that they will rub in the front.
2010 CGM 2SS/RS M6 LS3 Black/Gray
Exterior American Racing BLVD Black w/Machined(20x10) Mickey Thompson Street Comps(275/40 & 305/35)
Suspension Pedders Pace Car Pkg w/ZL1 Upgrade; Pedders Upper & Lower Control Arm, Steering, & Differential Mount Bushings; Pedders SS Brake Lines; Pedders Dual Bearing Camber Plates; ZL1 Toe Link; Hawk Performance Ceramic brake pads
Drivetrain Maggie2300(8psi-3.4pulley); CompCam; 85lb injectors; ZL1 fuel pump; ZR1 MAP; Centerforce DYAD Twin Disc clutch; Stainless Works LT headers; QTP Cutouts; Rotofab intake; RX catch can; Mike Norris tune 643rwhp 598 rwtq
SparkyDL75 is offline   Reply With Quote
Old 03-18-2013, 10:03 PM   #3
Deathmore
Drives: None Yet
I know that's exactly what I'm looking for. I dont see why it should really matter. The Camaro weighs as much as a small Pickup truck or SUV, and their rated for very high speeds. They also have a 420 AA A UTQG rating as oppose to the 220 AA A the P Zeros.
Old 03-18-2013, 10:14 PM   #4
San Carlos HotRods
Don Juan De Caro's
San Carlos HotRods's Avatar
Drives: 2012 2SS RS TF3 6M w/ Hurst Pkg. ,
It's a truck tire , it has different load ratings and compound , they are too stiff and will make the car very slippery ... And rough ... They will rub not a good call .... Good luck buddy , sounds like you need a little truck to run around in and keep your camaro in the garage for a good day
NOBODY EVER GOT SICK FROM SMOKING THEIR TIRES
San Carlos HotRods is offline   Reply With Quote
Old 03-19-2013, 06:56 AM   #5
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
Deathmore, those tires will NOT rub as some of the others have suggested.....they are nearly the exact same diameter as the stock there is only a .4" difference and using tires that size will make only your speedo off by .9 mph at 60.....so go for it.
Old 03-19-2013, 09:11 AM   #6
2010SSRSM6
2010SSRSM6's Avatar
The rim offset will determine how they will fit just as much as the actual width of the tires. I've seen 315/30/20's on all 4 corners with no rubbing, even in hard turns.
If your rims have the correct offset, you should be fine. If not you will likely have to add a spacer, but that gets tricky.
Old 03-19-2013, 09:14 AM   #7
Deathmore
Drives: None Yet
Thats what i figured, but I'm still new to cars and was looking for some better insight. Also Thank you very much Sir Nuke, it's hard to get a straight answer out of anyone on here when in comes to doing anything out of the ordinary to your car.
Old 03-19-2013, 09:18 AM   #8
Deathmore
Drives: None Yet
I was wondering about that. I have to get new rims regardless because right now I have 21s on my Camaro. I am working with Nine Ball now with some getting some help with that.
By the way Love your Car.
Old 03-19-2013, 09:23 AM   #9
2010SSRSM6
2010SSRSM6's Avatar
Thanks for the compliment!
Tony knows his stuff and can get you setup! Good luck with your choice.\
If you want to see what this size tire on an F14 looks like, check out SUX2BU's thread.
Old 03-19-2013, 09:21 PM   #10
Deathmore
Drives: None Yet
Do you guys think I should go with steel wheels for this or alloy?
Old 03-20-2013, 01:06 AM   #11
SPCBA
Drives: pleather and Chiclets
lose that weight! wheel diet
SPCBA is offline   Reply With Quote
Old 03-20-2013, 01:54 AM   #12
Deathmore
Drives: None Yet
Lol yea apparently there are no 18" steel wheels. Go figure, but thats alright I'm pretty sure I'm going with forgestar f14.
Old 03-20-2013, 03:50 AM   #13
SPCBA
pretty solid choice. what color have you decided on?
Old 03-20-2013, 04:09 AM   #14
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Why is it important to do more than 130 MPH?
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
