Old 03-23-2013, 07:14 AM   #1
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
NH-SS brass vs Hurst updated bushing.
I have the brass bushing from NH-SS and have not installed
It yet. Hurst is sending me a couple of there new updated nylon
Bushing with o-rings. I only want to do this once.
Pro and cons please.
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois
TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 )
JL Audio XD400/4 amp
Pfadt trailing arms & tie rods sway bars.
pedders street 1 package. ,Hurst short throw shifter
With bronze bushings .
skar is offline   Reply With Quote
Old 03-23-2013, 07:28 AM   #2
ssmike
BL1ZZRD
ssmike's Avatar
I have the NH-SS brass bushing and it really made a big difference! Nice crisp shifts with nearly zero slop! The only drawback is increased buzzing and vibration during hard acceleration. I can't compare it to the Hurst bushings though so it's your call. Hopefully someone can chime in here that has installed them. The only thing that would worry me about the Hurst fix is that they are still NYLON! When I removed the original Hurst nylons they were toast! Hopefully the new nylon bushings are more durable! Good luck!
Old 03-23-2013, 08:00 AM   #3
skar
skar's Avatar
Maybe I should buy the MGW and be done with it. Hate to spend more cash.
Did you use the vibration tape on install. May help ?
Old 03-23-2013, 08:50 AM   #4
ssmike
BL1ZZRD
ssmike's Avatar
I used the vibration pads on the upper shaft where the 2 bolt together. I didn't use the tape that they suggest on the lower linkage part because I didn't want it interfering with shift action. If you are in the market for a new shifter and haven't bought the Hurst yet save up for the MGW!
edit: I just noticed in you first post that you already have the Hurst. The MGW is a better set-up but it's pricy and you'd have to sell the Hurst!
Old 03-23-2013, 09:51 AM   #5
1sikRS
Drives: chevy
Hurst really needs to make a better product I sold mine cheap because of the slop bought the lsr tri ax and no problem since and it adjustable
1sikRS is offline   Reply With Quote
Old 03-23-2013, 10:05 AM   #6
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Mgw FTW
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 03-23-2013, 03:01 PM   #7
skar
skar's Avatar
Yes I have the hurst installed. Also have the fix brass bushing and the hurst updated on it way. Neither installed yet. Which to use?
Old 03-23-2013, 04:31 PM   #8
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
If it were me, I would go with the brass bushing. If you only want to do it once, use the one you KNOW will fix the problem, not the one you hope and think might fix the problem.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 03-23-2013, 06:09 PM   #9
ssmike
BL1ZZRD
ssmike's Avatar
1) MGW
2) Brass
3) Hurst nylon
Old 03-25-2013, 05:23 AM   #10
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
Forget about nylon bushings from Hurst
Install the NH-SS improved bushing
Making sure yo burnish it
If you dont like it then move off to the MGW
Jus-saying the NH-SS bushings does make that much of an improvement
I have 5k miles on mine Hurst with NH-SS bushing still tight no slop
Sent from my DROID X2 using Tapatalk 2
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 03-25-2013, 06:51 AM   #11
skar
skar's Avatar
RogerBzSS
? Any vibration noise.
Old 03-25-2013, 07:18 AM   #12
RogerBzSS
RogerBzSS's Avatar
Originally Posted by skar View Post
RogerBzSS
extreemly minor vibration IMPO
I feel it when I ride with the shifter as a hand rest
Noise No..
Old 03-25-2013, 07:20 AM   #13
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
where did you purchase the brass bushing from? I have the hurst and did not want to bother with the updated Hurst bushing because I knew it was still nylon.
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 03-25-2013, 07:23 AM   #14
RogerBzSS
RogerBzSS's Avatar
See Here
http://www.camaro5.com/forums/showthread.php?t=226328
The Material that NH-SS uses is actually a split 2 piece bushing made from oilite bronze
