03-24-2013, 11:17 PM | #1 |
Drives: 2010 CGM Camaro 2SS/RS Join Date: Jun 2012
Exhaust question..
I know this may be dumb; but what is the difference between a Cat back and a rear section exhaust? R-S is obviously cheapest of the two.
03-24-2013, 11:28 PM | #2 |
Drives: 2015 Z/28 #533 Join Date: Jul 2012
Cat back is exactly what it says... Exhaust that covers everything from the cats back to the mufflers. A rear section is just the mufflers themselves; the stock pipes remain untouched.
03-24-2013, 11:43 PM | #3 |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
Above answer is correct. Bear in mind either one is pretty much strictly for sound. None are considered power adders on a 5th gen.
03-24-2013, 11:48 PM | #4 |
Drives: Eve - 2011 Camaro 2SS/RS Join Date: Apr 2012
I mean, if it was exactly what it says...it would literally be a cats...back..
03-24-2013, 11:49 PM | #5 |
Drives: 2011 IOM Camaro Join Date: Jul 2010
Purrrrr-fect response!
03-24-2013, 11:50 PM | #6 |
03-24-2013, 11:59 PM | #7 |
so which is preferred?
03-25-2013, 12:34 AM | #8 |
Drives: 2010 SS/RS LS3 GFX Heritage grill Join Date: Jul 2012
I went with the Cat-back ,contact Chase @APEX. Quick delivery and the sound is excellent. Just depends on how much you want to spend.
03-25-2013, 05:31 AM | #9 |
03-25-2013, 06:52 AM | #10 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
truely it all depends on you, and what you really end up doing with the performance mods on your car. IF you are going to just do some minor things like the exhaust and a CAI, a Axel-Back or as you called it a R-S would be just fine. HOWEVER, if you are the type of person that saves their mods to reinstall them later when you trade in your car, get an cat-back and store they somehere. Fore if you get an R-S (Axel-Back), you cut off the mufflers and replace them, so unless you want to get them rewelded back on at the end, its a done deal.
03-25-2013, 07:29 AM | #11 |
Drives: 2011 2SS/RS Convertible Join Date: Mar 2013
Like daveagogo1 said above neither is much of a performance mod...more of a sound mod. I went with an axle back and got the sound I wanted, now my 2SS/RS sounds like a muscle car and not a prius!
03-25-2013, 10:59 AM | #12 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
