Old 06-20-2009, 07:03 PM   #1
Scott@Bjorn3D
L99 People Answer Only.
Can you take your car, put it in M and leave it in sport with the traction control turned off and get it to spin the tires?
And how do you think you car performs?
At this moment I am very dissappointed in mine. Got beat by a good 3 car lenghts buy a Mustang GT from the stop light. The girl was even spinning her tires and pulling away from me.
Scott@Bjorn3D is offline   Reply With Quote
Old 06-20-2009, 07:14 PM   #2
SRFnSNO
SRFnSNO's Avatar
Drives: Blown & Flamed
1st You got Beat by a Girl.
What type of power adders did the mustang Have?
Your Camaro is still stock?
I ran in a Poker run last weekend with all Porsche but my Camaro was let in.
Keep pace with this on NJ 539 through the Jerzy Pines. Passing bunches of Cars on the way down.
Braking had me a bit worried.
Most likley will end up setting my 2010 up for handling more than 1/4 mile.
Many mods to come. Tuning and FI
SRFnSNO is offline   Reply With Quote
Old 06-20-2009, 07:16 PM   #3
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
sport mode and manual mode are the only way to start off in first gear, also hold down the traction control button for 7 sec to turn off traction control and stabilitrac
car should have no problem breaking the tires loose
a trans tune really helps the car perform and drive better, gm has the trans tables set up purely for fuel mileage,, 6th gear at 30 mph is not needed, also a yank ss3200 would make your car night and day better
Old 06-20-2009, 07:19 PM   #4
Vash
Drives: 00 Blazer
Owners only?
I'll brake the rule then.
You should be able to learn how to street drag without changing stabilitrak modes.
There is a KITT sweet spot in the powerband. Where the traction control stays off and you give it as much as it takes without turning on.
Old 06-20-2009, 07:26 PM   #5
Scott@Bjorn3D
If I hold it in for 7 seconds and turn all that stuff off it still will not spin. It will only spin if power braking it.
A 400HP car should be able to break the wheels loose. I have 1900 miles on the car. From reading about other peoples L99 I think this is a issue that GM should fix. I think I will not be the only one complaining.
Old 06-20-2009, 07:35 PM   #6
camaro1
camaro1's Avatar
true, but 400hp is at the engine,, the auto cars only dyno 315-320hp at the wheels(manual trans cars dyno 360-380),, look under your car, the auto's have 4 cat converters, and a huge 34" x 11" resonator and 2 mufflers, that along with the trans tune really kill the performance of the auto,, gm was really trying to get fuel mileage from the L99 and auto trans
you want your auto to beat manual trans cars you need to:
1. tune the trans and get a converter
2. get the exhaust to flow
Old 06-20-2009, 07:42 PM   #7
Vash
Drives: 00 Blazer
Good advice. But I also think just need to relax and practice.
The car will come into it's own soon enough.
Did you put the secret weapon in yet? .... (Royal Purple 5/30).
Old 06-20-2009, 07:44 PM   #8
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
and 3., remove AFM with the tune as well..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 06-20-2009, 07:47 PM   #9
Melson
Melson's Avatar
Drives: Wild Cherry
I would agree.......when my L99 gets here its going in for AR Headers and Exhaust, cai, tune, and maybe a cam......will have to think about the converter.....but if its night to day difference then we may have to add it....
2010 RJT 2SS/RS L99 CAMARO
ARH 1 7/8" LT HEADERS W/ HF CATS
MAGNAFLOW 3" COMP EXHAUST
ADM PERFORMANCE CAI
ADM PERFORMANCE CUSTOM TUNE
ADM PERFORMANCE PORTED THROTTLE BODY
ADM PERFORMANCE TRANS COOLER
3.45 GEARS
BMR TRAILING ARMS
Melson is offline   Reply With Quote
Old 06-20-2009, 08:07 PM   #10
DanD
DanD's Avatar
Drives: 6 camaros
converter will be the #1 biggest gain. but should tune the car after for better driveability. Mine has full exhaust and converter and I tuned it also.. I will mess with the tranny tune for weeks I bet, to get it exactly how I want it. I agree its weird that they don't spin... but that doesn't mean they are slow, just a heavy ass car with good grip stock.
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427
2002 SSLE Convertible
1968 383 Camaro
1968 327 Camaro Convertible
1967 RS 327
1967 Pro-Tour LS3 in progress
DanD is offline   Reply With Quote
Old 06-20-2009, 08:20 PM   #11
novajess1972
I Done Caught Diabeetus.
novajess1972's Avatar
Drives: 1972 Chevelle SS/2010 Tundra
CANCELLED ORDER: 1SS/CGM/MN6/BLACK RALLY STRIPES
novajess1972 is offline   Reply With Quote
Old 06-20-2009, 09:12 PM   #12
erasedgod
CGM 2SS/RS
erasedgod's Avatar
Drives: # 9641
You guys keep talking about fuel mileage, but I'm getting about 14.5 mpg with conservative, mostly freeway driving. I can't imagine it could be much worse. My Trans Am got 20+ with the same driving.
More on topic, I'm happy with the performance of the car, but I haven't tried to race anyone. Just hit 800 miles.
Fastlane Pipeline Intake installed by MoToRZ TV
erasedgod is offline   Reply With Quote
Old 06-20-2009, 10:22 PM   #13
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
Scott, I was VERY dissappointed last night at the strip. I never do a "burn out" in the water box when I am running on true street tires, so I pull around it, then back up near the water box (but not in it), then turn the tires over a few times to clean them off. I did this last night (first run) in competitive mode, so I go to turn them over and it takes off like a boat anchor is tied to the rear, it looked ridiculous...I floored it, but it barely even moved forward. So before I staged, I turned everything OFF. I hit the button and turned TC off then held it for 7 seconds and turned stabilitrac off. I feel your pain though..at the track if you look at my thread where I posted my 1/4 video, I spin just a little out of the hole on my fastest run. I would certainly not say they went up in smoke or anything, however, it was on a fairly well preped track. But I can't see it doing much on the street either. Normally I would say, this is an advantage b/c "spinning aint winning" but if you have a fairly powerful car, spinning is a byproduct of that power, and usually you have to run DR to put the power down.
I really think you need to 1st check with your dealer to make sure everything is kosher, then if you can't get any satisfaction from them, take matters into your own hands and start with the performance aftermarket. It all depends on how much you want to spend, how much "comfort" you are willing to give up, and how far you want to go (performance wise).
If I were you and wanted to stay "bolt-on", I would get a good CAI, ARH headers and whatever axle back sounds good to you, a stall (yank or Vigilante) and a dyno based tune to bring all those things together. FYI, my TBSS ran 14.8 @ 93 in weather like we are having now bone stock, then with the mods mentioned above, it ran 12.8 @ 103 in better weather. Just showing how much of a difference weather + mods made...2 seconds and 10 mph with 4 mods. My TBSS weights almost 5K lbs, so I would expect since these mods would actually make more power on the L99, you make gain more.
I would also say that if you don't mind going to this extent, I would get a mild VVT cam and do the AFM delete...since you have to remove the heads when you install the AFM delete kit (pretty sure on this), you could install a thinner head gasket and get a little compression back (since your down on CR from the LS3). Either way, I'd have my tuner get rid of the AFM part of your tune.
I am resolved to the fact this is slower than what I expected, BUT, with the amount of aftermarket stuff for this car, it will be my fault if it stays that way.
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 06-20-2009, 10:43 PM   #14
coolman
Guest
If you read the last car and driver test on the mustang vs camaro. It would lead one to believe that the mustang would beat the A6 L99 because it's not much slower than the LS3 with the M6. Did anyone do a test on the l99 yet?
coolman is offline   Reply With Quote
SAE HP/Torque Curves for L99 & LS3 ls2gto Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 40 05-16-2011 07:43 PM
Competition CAMS nearly ready to release their L99 cams for the VVT AND AFM! PatrickfromMD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 32 07-30-2009 06:46 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
Just a voice of Reason Whitten Off-topic Discussions 56 05-28-2009 11:00 AM
Have People lost their common sense? lil_chef General Automotive + Other Cars Discussion 25 02-09-2009 12:05 PM
