Old 04-15-2013, 10:43 PM   #1
siriusdish
Drives: 2010 Camaro L99
160 not opening?
Put in a new thermostat and it never opened. Is there a trick?
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
Old 04-15-2013, 11:13 PM   #2
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
One mistake I see people make is they assume their car should run at 160 with the T-stat. 160 is the temp it opens at..not the temp it holds the car at. Normally a 160 stat will have the car run 10-15 degrees cooler...like 200-210 range if I remember right.
Otherwise make sure the system is bled right.
MarylandSpeed is offline   Reply With Quote
Old 04-15-2013, 11:42 PM   #3
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
Thermostat opens around 160 but the fans control the actual coolant temp. Mine are in the 190s while idle
DarkCry956 is offline   Reply With Quote
Old 04-16-2013, 12:11 AM   #4
siriusdish
went to 245, kept climbing
2010 L99
Old 04-16-2013, 12:20 AM   #5
MaxKamai
Mad Ninja Skills
MaxKamai's Avatar
Drives: 2011 Camaro SS/RS M6
Did you properly bleed/burp the system of air after the install?
2011 Camaro SS/RS M6 - 633whp/679tq Gave to the wife
Custom stainless 2" primary headers / Custom stainless 3" header back exhaust / Hurst short shifter / ZEX nitrous kit / Vararam intake / Spohn chrome moly trailing arms / Sin City Performance Tune / SCP custom ground cam / SCP ported & polished heads
New Car 2007 Corvette Z06 - Headers / Vararam / Magnaflow Catback / SCP Tune / Nitrous / BTR Stg IV Cam and Springs
MaxKamai is offline   Reply With Quote
Old 04-16-2013, 12:23 AM   #6
siriusdish
No, that is what is wrong, googling how to
2010 L99
Old 04-16-2013, 12:31 AM   #7
MaxKamai
Mad Ninja Skills
MaxKamai's Avatar
Easily overlooked
Old 04-16-2013, 12:52 AM   #8
siriusdish
Yes, I'm a nut, On well, sent my Dad a FB message.
2010 L99
Old 04-16-2013, 01:29 AM   #9
Denis
Denis's Avatar
Drives: 2010 SS
Did the new stat have that little air bleed hole in it thats supposed to on the top side of the stat? easly overlooked if you've never done one. not sure if these have one.
Old 04-16-2013, 02:40 AM   #10
siriusdish
Will check, ty
2010 L99
Old 04-16-2013, 04:45 AM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
^^^ no such thing, it's a biach burping it on these cars. It took me a few times to get it right seeing high temps then turning the heater on high then adding more coolant and squeezing the hoses to move the coolant until it finally burped. I think I must have shut it down like 3 times. I was pissed lol. This was back in 2010 so there were no writeups lol
Old 04-16-2013, 05:58 AM   #12
Denis
Denis's Avatar
Drives: 2010 SS
these dont have that little valve? good to know
Old 04-16-2013, 06:50 AM   #13
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Yep, do this. Big pita. I had issues after doing heater hose relocation. Got to 230+ a few times. Left the rad cap off in order to top off as it burped. When it would burp, it splashed everywhere. All over my new CAI and the fans blew coolant all over the engine and bay. Was hating myself, thought I did something wrong. May want to add some water wetter as well at this time.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 04-16-2013, 09:28 AM   #14
Alvin@PCMofNC
Drives: 2010 IOM RSS
It really sounds like a bleed issue. You can actually test it by putting in a boiling pot of water.
The 2010+ Camaros are not hard to get to bleed but most people do not get the upper hose full. Squeezing it while refilling the coolant does the trick.
Alvin@PCMofNC is offline   Reply With Quote
