Old 04-16-2013, 04:54 AM   #1
sting808
Drives: 2010 SS RS
Need "how-to remove" options for Rear Upper Bushing
Professionals, please advise.
I just read Nathan Moreno's post on how he removed the bushing from the rear upper arm bracket. Cut out center, heat to loosen adhesive, hammer in screwdriver and collapse sleeve. (He's probably going to media blast and powder coat the bracket)
I haven't seen it closeup, but can it be pressed/pulled out without using a hydraulic press? I'm pulling my cradle to install a ZL1 pump and replace rear upper bushing. Already did my sub-frame bushings the hard way and when I saw Rob's(Wretched) socket between frame solution... DOH !!!
sting808 is offline   Reply With Quote
Old 04-16-2013, 07:47 AM   #2
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
I had a friend at a local garage use a ball joint press. It's about 2/3rds down the write-up
http://www.camaro5.com/forums/showthread.php?t=289431
I wish I had just bought the bracket with the bushing already pressed in like this one from JDP
http://www.jdpmotorsports.com/manufa...ss-v8-jdps1001
jeremywes is offline   Reply With Quote
Old 04-16-2013, 06:09 PM   #3
was619
Billy The Kid
was619's Avatar
Drives: Cyber Grey 2SS/RS
Similar to Nathan I also had to cut/bend the metal ring to remove it but it wasn't too hard after i got the brakets off the frame and on the work bench.
Good luck with it.
The two DIY threads above seem to outline it all pretty well.
CGM 2SS/RS[SIZE="1"]
Performance: LT Headers/Stainless Works cat-back, 225/233 Cam, 1LE 3.91 gears, Custom Tune, BMR suspension,
MGW Shifter, Stainless brake & clutch lines, Ideal G Master Cylinder, 275s on all 4 corners
Aesthetics: ZL1 Spoiler, DIY LED marker lights, AACPlasma DRL, Yellow Calipers, painted factory wheels
was619 is offline   Reply With Quote
