Old 04-20-2013, 12:04 AM   #1
WCoolBreeze
2SS
WCoolBreeze's Avatar
Drives: 2016 2SS, Red Garnet Tint
Check Engine Light On
This evening I decide to go gas up my 2LT/RS Camaro for the weekend, it has been sitting for most of the week. Well before I was even half way to the gas station I normally go to, my Check Engine light came on and the feel of the car changed. After I made a left hand turn I pulled over to the side of the road and hit the blue "OnStar" button and asked them to check for codes. They came up with two of them. The fiirst one they said was for the Transmission (P2715) and the second one was for the engine (P0700). I asked them if it was safe to drive the car and their response was to take it to the dealership within 7 days. I completed my trip for gas, after shutting down the car and starting back up light still on, drove home slowly and shut down again, let the car sit for a few minutes, then started her up again, and light is still on. I plan to check her in the morning to see if I still have the check engine light. Any ideas or suggestion for my problem.
Walt B.
2016 Camaro 2SS
2005 Dodge Magnum R/T (Yes it has a Hemi)
1987 Camaro RS (California Special) - For Sale
Gen6, 2016 Camaro 2SS, Red Garnet Tint (with Silver Rally Stripes)
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Delivered: 4-26-2016
WCoolBreeze is offline   Reply With Quote
Old 04-20-2013, 12:14 AM   #2
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
I just googled them. Both of them are transmission codes. P2715 is something about a pressure control solenoid. P0700 is just a generic fault apparently. Not sure what that actually means. You'll probably have to take it to the dealer.
Is the transmission slipping at all?
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive."
. 2022 1SS 1LE (Coming Soon)
fielderLS3 is offline   Reply With Quote
Old 04-20-2013, 12:22 AM   #3
WCoolBreeze
2SS
When the light came on I notice a change in the car power, more sluggist. It seemed to be shifting OK. Except once the light came on I did not drive as I normally do, I took it very easy and stayed at a low speed.
Walt B.
2016 Camaro 2SS
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Old 04-20-2013, 01:04 AM   #4
LoneStar
LoneStar's Avatar
Drives: 2011 IOM Camaro
Walt B.
I believe that code automatically puts the car in "limp mode", which is probably what you felt. I'd take it to a trustworthy dealer. It may be a problem with the TCM or a component inside the transmission. How many miles are on the car?
LoneStar is offline   Reply With Quote
Old 04-20-2013, 01:10 AM   #5
WCoolBreeze
2SS
I am presently at 27065.0 miles. I use my 2005 Magnum as my daily driver. My Camaro is my Fun Car.
Walt B.
2016 Camaro 2SS
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Old 04-20-2013, 01:15 AM   #6
LoneStar
LoneStar's Avatar
Walt B.
That's less than half my mileage... Warranty will cover what's wrong, but still hopefully it's not a big problem. Good luck, keep us updated!
Old 04-20-2013, 01:20 AM   #7
WCoolBreeze
2SS
I am past my 36 month warranty on the car, but still in my powertrain warranty. Where exactly is this pressure control solenoid located? Plus I have to wait until Monday afternoon or Tuesday morning to take my car in. I am just glad I have another car to count on.
Walt B.
2016 Camaro 2SS
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Old 04-20-2013, 01:29 AM   #8
LoneStar
LoneStar's Avatar
Walt B.
I would think it would be covered under the powertrain warranty... More than likely, you have to remove the transmission fluid pan to see it.
Old 04-20-2013, 08:12 AM   #9
Chevrolet Customer Svc
Drives: GM Vehicles
Walt B.
Greetings Walt,
Sorry to hear about your transmission and engine concerns, but I would like to assist in this case. If you haven't taken it to a GM dealer, then I can happily schedule an appointment for you at your earliest convenience. There may be some options we can explore in these matters. If you'd like, please private message me the following information:
-Full name
-Phone number
-VIN
-vehicle mileage
I look forward to hearing from you soon!
William R.
Chevrolet Customer Care
Old 04-20-2013, 02:44 PM   #10
WCoolBreeze
2SS
PM sent
Walt B.
2016 Camaro 2SS
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Old 04-20-2013, 07:07 PM   #11
TooCool5
TooCool5's Avatar
Try a fuse pull and see if that takes care of it.
You could always bring it in on Monday.
Old 04-21-2013, 12:02 AM   #12
WCoolBreeze
2SS
What fuses would I need to pull to reset and clear the computer? Also would it take the car out of the limp mode of operation that it is in right now.?
Walt B.
2016 Camaro 2SS
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Old 04-21-2013, 06:44 AM   #13
montreal2010yellow
montreal2010yellow's Avatar
Walt B.
Fuses 5 and 20 for at least 1 hour. But it might be better to disconnect the battery (negative) for a few hours or overnight.
Was you car strored and if so did you had Stabil Fuel treatment. Could be bad fuel only.
Old 04-21-2013, 10:06 AM   #14
SC2150
Solinoide pressure CEL code are trans valvebody related....could be simply low on fluid, but get to the dealer as this is part of the drivetrain. If driven low on fluid the trans dosen't last long. DON'T delay....get to the dealer asap.
Good luck!
