They see me trollin'...
Drives: 217 ci of fury; Chauffeured by SS Join Date: Jul 2011
Amsoil for the Camaro?
My guy uses it in his SS and I just switched. When I checked the oil it wasn't dirty at all (been using Valvoline Durablend) so I don't trust the oil monitoring system a bit. It started complaining at me wanting a change at 5k but after looking I think I could have gone ten.
So here I am making the switch to full synthetic; the car has 66k now and I figure it would be better for it. I'd never heard of Amsoil till Zachary told me about it and he swears by it in his SS. Anyone here use it? V6 or SS. Thoughts?
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread |
![]() Drives: 2013 Camaro 2SS/RS/1LE Join Date: Feb 2013
I use the Amsoil Signature Series in my SS. I switched to full synthetic (Group IV) oils a few years ago. I don't have a lot of feedback because I never had issues with other oils, but the extra protection never hurts.
http://endurancesynthetics.com/info/avm/amsoil-vs-mobil-1.html
____________________________________
![]() Modifications: HSA Elimination - Cold Air Inductions Intake Solo Performance Mach Cat Back - Skip-Shift Eliminator |
#3 | |
![]() ![]() ![]() Drives: . Join Date: Mar 2012
If you like it and are willing to spend the money on it, then go for it. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: COTW 8/29/11 2010 CAMARO Join Date: Jul 2009
Well I have to say I went in for a oil change to a performance shop while having other work done and he wote up the oil change with AMSOIL and its like 20 bucks more and I told him that I wanted to stick with the Mobil 1 try and Stay with GM stuff in the car and he explained why is better and after going back and fourth he gave it to me for the same price just to try it out he said its the oil he will use and explained why is so much better
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: pleather and Chiclets Join Date: Mar 2012
i use amsoil z rod for my cammed v8. i have tried a few different oils. mobil 1 is crap and so are most mainstream brands now. they took out the good stuff of the oil that reduces wear to protect your cats because big brother frowns on things that are good for the car and bad for cats. i dont know how its overhyped because so very few people use it comparitively to mobil.
oils high in zinc and phosphorous is what you want if you want your car for a long time. amsoil z rod has done me well as a daily driver and on a road course. I am amused by folks who are not willing to spend a tad more on oil for a 40 k car. Amsoil is not hard to get its just not at autozone. they have dealers around the country and also sell via internet and snail mail. there are 15 amsoil dealers located within 20 miles of me.
#6 | |
#7 | |||
![]() They had a study long ago about the sheer stability of the oil, but in a particular machine of mine that was hard on oil it sheered during the UOA. Mobil 1 sheered as well. The only oil that did not was Valvoline VR1. When you do your own comparison and put yourself at the top of the list in sheer stability then your oil sheers, then i consider it over hyped. So yes it's a good oil, but there are oils just as good that as cheaper and more easily accessible. Here is an independent wear study. http://speedtalk.com/forum/viewtopic.php?t=30483 Amsoil is in the to four, but Mobil 1 is above it: Quote:
#8 | |
Flying Low & Raining 3's
Drives: 2012 Camaro SS 45th Ann. Edition Join Date: May 2012
Several years ago I searched for recommendations on the best oil filter I could find and it led to Amsoil products. I'll admit, I was somewhat unaware of Amsoil, but the more I use the filters and oil, the more impressed I am. Pushing 8 quarts of oil through these small filters, I want the best protection I can get. You can purchase it directly from Amsoil for a discount, but there are many local dealers including some NAPA stores. Along with premium gas, if your going to spend a couple extra bucks on your car put it in the life-blood - the oil.
#9 |
shearing isnt the whole story of oils antiwear properties.
"After the base oil has sheared or squeezed out, The last line of defense is an additive that puts down a barrier film. This additive usually has higher levels of strength against shearing so it helps keep the wear down. Alright, here's the catch. In 96, the lubrication industry changed from the SH to SJ API rated oil by reducing the barrier lubricant additives to help preserve cat converters on cars. Why?, It appears that the manufactures / lubrication experts are concerned with contaminating the cat converters with the standard antiwear additives in the motor oils so they have reduced the levels of antiwear additives to preserve the cats. Hmmm, guess what, When they introduced the new SL GF-3 oils, They left it the same. Ok, not out of the woods yet... Now the new GF-4 oils are in the works in hopes to be introduced next year around April. Have a guess one of the things they are going to do?, YEP, reduce the current antiwear additives again." quoted from bob the oil guy http://www.bobistheoilguy.com/oilshear.htm another quote from same article "All base oils film strength will shear under stress or pressure. The real way to help prevent wear is to maintain higher levels of antiwear additives This in conjunction with a good base stock which resists breakdown to high heat." soooo basically if you rank by shearing only sure ya cool the cheap oils are better because they have lower stuff that protects after shearing. there is three ways oil helps lube and or protect from wear. its shearing properties is only one...and not the most reliable one. i am not a use the DIC indicator to change my oil guy either imagine that...my oil gets changed after each track weekend. i have tried 5 different oils in my car now. Three on a road course. the z rod held up the best on a roadcourse. gibbs and vr1 both broke down... vr1 was the worst. gibbs broke down after two straight days of track time and 400 mile round trips to track. good info cbass, its not the whole story tho.
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 LS M6, Black Join Date: May 2009
John B.
1995 Mitsubishi Montero SR 1987 Dodge Raider Turbo Project 1986 Mitsubishi Montero 2.4l FI Transplant |
#11 |
2 oil analysis, magnetic plug and filter sleeve, temperature (not the guage on the car), cutting open my filter, driving as a daily and on road course, and observation. its not a butt dyno if thats what your asking.
#12 | ||||
Either way blindly recommending oils even if they have worked for me in the past is a crap shoot. It's best spending the money on a UOA and seeing how the oil performs in your car under your driving conditions regardless of past performance. You also need to also have some knowledge of what metals are inside your engine as some oils are not yellow metal safe and will be corrosive. There are many factors to consider. Last edited by cbass; 04-23-2013 at 01:43 AM. |
#13 |
more good info cbass. I would agree that each person interested in keeping their car for the long haul should invest some time finding the right oil for their car and driving scenario. If they are a 2-3 year and trade person who cares put the cheap stuff in.
#14 | |
