Old 04-23-2013, 12:43 PM   #1
bumblebeecamaro
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS
What size magnetic oil pan plug for my ZL1?
I want to start using a magnetic oil drain plug on my Z, but I don't know what size or thread pattern it is.
any insight on which one I need?
bumblebeecamaro is offline   Reply With Quote
Old 04-23-2013, 12:44 PM   #2
npd337
Drives: 2013 Ash Zl1
http://www.drainplugmagnets.com/recentgmandbuick.php
npd337 is offline   Reply With Quote
Old 04-23-2013, 01:33 PM   #3
jsd
jsd's Avatar
Drives: 2012 ZL 1 #370
Is the stock one not magnetic.
jsd is offline   Reply With Quote
Old 04-23-2013, 01:59 PM   #4
Cybeast
Cybeast's Avatar
Drives: 2013 Victory Red ZL1 #1562
Stock one is not magnetic. NAPA part number 704-1903 is 5.00
Cybeast is offline   Reply With Quote
Old 04-23-2013, 02:25 PM   #5
jsd
jsd's Avatar
This one.?
http://m.napaonline.com/Tablet/parts...erchange=false
Old 04-23-2013, 02:44 PM   #6
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
If you don't want an aftermarket oil drain plug you can always go "old school". Back in the day we would just get a really powerful magnet and stick it on the bottom of the pan near the plug. Before draining you pull off the magnet and the rushing flow/drainage of the hot/warm oil sweeps out all the particles. I purchased one from Dimple (www.drainplugmagnets.com). But there are a ton of aftermarket ones. Dimple seems to be the high end of the scale, very powerful, so they advertise.
Normagene is offline   Reply With Quote
Old 04-23-2013, 02:48 PM   #7
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
As long as it sticks to our aluminum oil pans it should work great
Sent from my BlackBerry 9900 a 1/4 mile at a time
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff
#BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 04-23-2013, 02:57 PM   #8
Cybeast
Cybeast's Avatar
Originally Posted by jsd View Post
Yes make sure magnetic isn"t loose
Old 04-23-2013, 03:41 PM   #9
bumblebeecamaro
Car Lover By Nature
lol Too funny.
Old 04-23-2013, 04:13 PM   #10
Normagene
Normagene's Avatar
Yeah, I did say "old school". That was then and like I said I ordered mine from Dimple. Can't tell ya how well it works since I haven't done my second oil change yet. Times have changed. Watched a country boy on you tube make a catch can for his pickup using an old pickle jar. LOL, to each their own!
Old 04-23-2013, 05:06 PM   #11
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
They also make a magnet for the oil filter if your going for overkill !!
Laus Deo
charlietuna is offline   Reply With Quote
Old 04-24-2013, 05:27 PM   #12
bumblebeecamaro
Car Lover By Nature
I ended up getting my magnetic plug from a local auto parts store. A little over $4 plus tax. That'll work for me.
Old 04-24-2013, 06:15 PM   #13
jbotta
jbotta's Avatar
Drives: Camaro ZL1
Watch this vid, I also agree with DIMPLE drain plug for 34 $ its a good buy and you know its going to work. Its built tuff so threads dont fall apart and the end of the magnet dosnt break off and go flying around inside.I would say stay high end even if its just an oil plug. Hope this vid helps .
jbotta is offline   Reply With Quote
Old 04-26-2013, 09:15 PM   #14
Normagene
Normagene's Avatar
jbotta. Top Notch. Excellent video demonstration of the power of the Dimple Magnetic Drain Plug. I thought it was expensive when I first ordered mine, but after seeing this video, WOW. I definitely got my money's worth. Looking forward to the next oil change to see what if anything it collected.
