Old 04-27-2013, 09:36 PM   #1
BDON_DBB
BDON_DBB's Avatar
Drives: 2010 Camaro SS D1SC
Question best way to get my LS3 BUILT
buy already built shortblock from texas speed or other place of recomendation or buy a rotating assembly and try and find someone to install it. Im looking for the least expensive and relible rout togo. Im aiming for 1000rwhp
BDON_DBB is offline   Reply With Quote
Old 04-27-2013, 09:59 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Do some research on builders/shops, pick one you like, talk with them what your goals are and/or how you want to use the car, give them your car.
Eventually you'll probably want your car back, so don't give it to them for "keeps"
Click to view my build thread
Old 04-27-2013, 10:03 PM   #3
avellanet.jr
Emerald Coast Camaros
Drives: 2014 ZL1 #77
Hit up Matt from FSP. They come up to PCB almost every month to do. Many will vouch for him and Rodney.
avellanet.jr is offline   Reply With Quote
Old 04-27-2013, 10:07 PM   #4
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
LS3 block won't do 1000whp, sorry. You need 6 bolt heads to do that, trust me, I know the feeling. To do it right, you're talking 15k in the motor only, and then it needs to be Installed if cant do it yourself. Then, add 3k to the bill for incidentals, all in all you have a 20k+ motor for 1000whp... And you don't even have a power adder yet
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 04-28-2013, 12:02 AM   #5
BDON_DBB
BDON_DBB's Avatar
Haha that you know of. Anf i beg the differ that the ls3 is incapable of 1k
Old 04-28-2013, 12:11 AM   #6
2SS45th
2SS45th's Avatar
It really isn't, but if you want to blow the heads off of your car, it's up to you.
Old 04-28-2013, 12:19 AM   #7
BDON_DBB
BDON_DBB's Avatar
The heads would be done ofcorse. Im not talking stock heads here
Old 04-28-2013, 12:34 AM   #8
BDON_DBB
BDON_DBB's Avatar
Old 04-28-2013, 12:35 AM   #9
BDON_DBB
BDON_DBB's Avatar
Been done already
Old 04-28-2013, 12:48 AM   #10
2SS45th
2SS45th's Avatar
4 bolt heads are very different than 6 bolt heads. I'm not saying it can't be done, it just won't last.
That video is of a motor just like mine, an LSX block with forged components, very different from an LS3. Before you jump into this you should do a lot more research, it will be time well spent.
Old 04-28-2013, 04:18 AM   #11
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
The best way to go is to do all the labor yourself and get an lsx 416. Price will come down to about 9.5k.
K32 Camaro is offline   Reply With Quote
Old 04-28-2013, 06:16 AM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Contact AES
http://aesracing.net/ Just keep in mind it's silly season lol
Iirc they were welding an ear on the blocks for a 6 bolt head. How much boost will you be using? Will you be going s/c or turbo?
It turbo you won't be needing 6bolt heads. I've seen plenty of Ls1/2/3's with forged internals and ARP head studs IN the 900's you'll be fine.
Good luck
Old 04-28-2013, 06:20 AM   #13
The Stig
The Stig's Avatar
Whoops, missed that 1,000 rwhp part.
Yea OP, an LS3 can't safely/reliably make 1,000 rwhp without you having to worry about something breaking.
Old 04-28-2013, 09:21 AM   #14
Unreal
Drives: 2006 Z06
Block would need to be sleeved for 1000hp.
4 bolt heads are fine if setup properly. There are plenty of cars running 1100-1300hp with 4 bolt heads. Just need the crazy expensive ARP bigger ARP studs. 1/2" L19 studs will hold 1000hp easily with a thicker deck aftermarket head.
Nick
Corvette Z06 -1200ish rwhp
matt @ fsp
