Old 04-29-2013, 08:38 AM   #1
dcoates18481
dcoates18481's Avatar
Drives: 2010 CAMARO RALLY YELLOW SS/RS/M6
Roll control installation...brake bleeding question?
I have bled brakes on other cars before but not my Camaro... after i install the roll control on my 2010, is there anytthing different i need to know to bleed the fronts out?
Don't want to screw this up!!!
Thanks.
I LIKE TO GO FAST!
Lethal Racing Night Fury Cam Kit, Melling oil pump, C5R Timing Chain, Dyno Tuned by Shawn@Lethal Racing, Vararam Tuned intake, Vararam Power Wedge, LSR Tri Ax Short throw Shifter, VMAX Ported T/B, TSP 2" L/T Headers, TSP Cat delete, Borla axle back exhaust, Innovate A/F monitor, 471.7 HP/438.8 TQ
dcoates18481 is offline   Reply With Quote
Old 04-29-2013, 08:49 AM   #2
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
I would bleed all 4 and remember to bleed the inside and outside valves on each caliper
jeremywes is offline   Reply With Quote
Old 04-29-2013, 08:59 AM   #3
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Good advise!!! Bleed the inner bleed ports first, and then the outer. Additionally, I would recommend the Motive Power Bleeder. Me and a buddy tried bleeding the old-fashioned way, but it didn't work so good, still had mushy brake pedal. After using the Motive Power Bleeder, everything was perfect.
blazzin1 is offline   Reply With Quote
Old 04-30-2013, 09:30 AM   #4
dcoates18481
Smile
which cap fits our cars for the Motive Power Bleeder.
gonna order one of these today!
I LIKE TO GO FAST!
Old 04-30-2013, 09:54 AM   #5
blazzin1
blazzin1's Avatar
You can use either the 0108 or 0118. I got the 0118 that has an aluminum anodized cap, and used the thinner gasket with it. Works perfectly!!!
Old 04-30-2013, 10:30 AM   #6
dcoates18481
THANKS!!
I LIKE TO GO FAST!
Old 04-30-2013, 10:42 AM   #7
dcoates18481
Any of our vendors sell these?
looking to buy one.
I LIKE TO GO FAST!
Old 04-30-2013, 12:13 PM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
I've bleed the brakes on a few times on a 5th Gen (mine and a friends) with both DOT 3 and DOT 4 and I did it the old fashion way. Worked without issue. Just follow the old...farthest away routine. Do the passenger rear, driver rear, passenger front, driver front and make sure to get the inner and outer.
Now would be a good time to upgrade to stainless steel brake lines and/or use Motul 600 DOT 4 fluid. It only took 2 bottles to do my DOT 4 conversion.
Build Journal
Old 05-01-2013, 02:42 PM   #9
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
I don't want to start a new thread since i know Ive seen it here. I need to know what name brand that is recommended here for the 1 man brake bleeder?
cornerspeed92 is offline   Reply With Quote
Old 05-01-2013, 02:44 PM   #10
blazzin1
blazzin1's Avatar
See Post #3
Old 05-01-2013, 05:21 PM   #11
cornerspeed92
See Post #3
Yep, that's the one i was talking about,thanks.
