Old 05-07-2013, 11:06 AM   #1
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
Front engine cover oil leak
Well the dealership will have my Camaro for a couple days to fix a small leak from the front engine cover. They can't quite tell if it's from the head gasket or exactly where it's coming from, even after they added dye to the oil.
Has anybody else had something like this? Anything I should look out for?
On the plus side I get to drive a caddy for a while since it is warranty work!
terry_b is offline   Reply With Quote
Old 05-07-2013, 11:56 AM   #2
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
Check the section on issues and problems. One guy on here has had the same problem more than 4 times. He traded in his V6 ultimately. I think his name is NYRfan. You can search for his posts. It was titled with "oil leak".
Hannibal is offline   Reply With Quote
Old 05-07-2013, 01:22 PM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Probably the timing chain cover (If towards the front), it's somewhat common on the V6.
http://www.camaro5.com/forums/showthread.php?t=236091
FSP tuned: 377/389
Old 05-07-2013, 04:16 PM   #4
Chevrolet Customer Svc
Drives: GM Vehicles
Hello terry_b,
We do apologize for this small oil leak issue you're having right now. We definitely want to correct this as soon as possible and get you back into your Camaro. I see you’re already at the dealer for service which is great. If you should have any questions or concerns going forward, you can use us as a reference here on the forum as well.
Reggie B.
Chevrolet Customer Care
Old 05-16-2013, 08:26 PM   #5
terry_b
terry_b's Avatar
It was actually the head gasket. Dealer confirmed it was failed after disassembly. They did great, no problems so far!
