Old 05-18-2013, 04:35 AM   #1
IBM camaro
Texas HT5
Drives: IBM
Help! Car keeps stalling
Hey everyone I really need help and ideas here from anyone knowledgable I have the IpF kit on my car with the V3 supercharger. My car is an auto and is IPF tuned the problem is that when I'm driving around and stop or take off slowely from a stop then stop again my car stalls out. I've had 3 retunes and it got better but has not stopped any ideas why? The idle is fine once it starts the rpms dip to below 700 when coming to a stop only in 1 gear the rest when downshifting stay above 1000
IBM camaro is offline   Reply With Quote
Old 05-18-2013, 05:14 AM   #2
IBM camaro
Texas HT5
Drives: IBM
I'm looking for mechanical solution so please don't blame the tune yet.
Old 05-18-2013, 05:50 AM   #3
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
To me it just sounds like the idle needs to be raised alittle.
chevy 3 is offline   Reply With Quote
Old 05-18-2013, 07:56 AM   #4
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Maybe check the entire intake system for a leak? Could be leaning out? Idk..lol
DarkneSS is offline   Reply With Quote
Old 05-18-2013, 08:05 AM   #5
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
That has to be something in the tune
2014 Black 2SS/RS 1LE
V6owner is offline   Reply With Quote
Old 05-18-2013, 08:38 AM   #6
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Have you check the codes? Sounds like a vacuum leak .
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 05-18-2013, 08:43 AM   #7
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Tune, sorry. They have tunes with notes that say :NO STALL, so I'd assume they have seen this before. I have never had this issue with mine. Hope you get it figured out.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 05-18-2013, 09:41 AM   #8
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Had a similar issue with my M6 with the first tune I had. When I would depress the clutch when coming to a stop the idle would dip and sometime stall. Arno tweaked the idle and this hasn't happened since. Have seen issues also when the MAF splice is not done right. I soldered my splice instead of crimping and used boating heat shrink. Might want to check the splice to see if it's intermittent.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 05-18-2013, 10:33 AM   #9
blackTT600
Drives: 2011 2LT M6 SC
prob tune, but look at your throttle body make sure its good and clean.
blackTT600 is offline   Reply With Quote
Old 05-18-2013, 11:37 AM   #10
iceman5730
Iceman
iceman5730's Avatar
Drives: 2011 Camaro 2LT SC/RS CGM
Mine does the same thing Its an Auto somethimes drops below 500rpm then pops back up. on occasion it will stall but only when I use the paddles.
I think its the tune
iceman5730 is offline   Reply With Quote
Old 05-18-2013, 11:46 AM   #11
Missionboi
SoCal HT5 [COTW: 8/12/13]
Missionboi's Avatar
Drives: 2013 2SS 1LE RS
mine had the same issue with the RX supercharger, my MAF sensor was bad and got another and BAM all gone!
Missionboi is offline   Reply With Quote
Old 05-18-2013, 12:30 PM   #12
IBM camaro
Texas HT5
Drives: IBM
Thank every one no leak codes no codes at all.
Old 05-18-2013, 12:47 PM   #13
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Funny you should bring this up. My car (auto) hasn't actually stalled, BUT the idle feels ever so slightly rough and sometimes it feels like it MIGHT want to stall / misfire but it doesn't. I have however had it misfire twice on me in the last month or so. I've talked to people about this and some think it is the spark plug gap. I WAS running around 0.035-0.036. I literally just finished changing out my spark plugs (with new ones) and opening the gap to 0.038-0.039. It seemed to have helped. But I'm not sure about IPF since they suggest to gap down to 0.032ish
Another thing is, it could be the tune.
This is another possibility. Given that I've had MAF sensor issues in the past.
BaylorCamaro is offline   Reply With Quote
Old 05-19-2013, 11:19 AM   #14
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
Steps to resolution based on replies,
1. Check for leaks.
2. Check for tune issues.
3. Clean MAF
4. If clean MAF does not help, purchase new one.
5. If resolution is not found, repeat steps 1 - 4.
Ir0nM4n is offline   Reply With Quote
