Old 05-21-2013, 10:29 PM   #1
manu_b
Drives: 2010 Camaro inferno orange 2LT RS
BA amplifer input
I would like to know if the output by the BA is low level or speaker level. As if its speaker level then i can put a car pc in between stereo and amp. In the computer a dedicated sound card with virtual surround sound. If its low level then i can look towards other option such as alpine imprint etc.
manu_b is offline   Reply With Quote
Old 05-21-2013, 11:03 PM   #2
lfree11012
lfree11012's Avatar
Drives: 2018 1LE
From the head unit it is a low level single to the oem amp It sound like your looking almost for a aux input
lfree11012 is offline   Reply With Quote
Old 05-21-2013, 11:30 PM   #3
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
It's definitely a "low level" signal. Also, I can't understand you saying you'd want to run line-level (or high level) inputs into a car PC. I don't know of any sound card I have ever seen that accepted a line-level input. I think the IMPRINT has the ability to accept line and low level inputs - perhaps you got it backwards?
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 05-22-2013, 01:15 AM   #4
manu_b
I have a creative sound card. The way I use it right now is I have two different input sources connected to it and then listen to the songs through pc speakers. I did a experiment with my car. I fed my pc audio into cars aux jack and turned on all the enhancments and the quality of the sound was really good and it did mimic the surround sound, also I have all the parts at home, so it's cheap way. But anyways if it's low level then I think I will buy imprint
Old 05-22-2013, 01:19 AM   #5
manu_b
You are right , I think sound cards won't handle it
Old 05-22-2013, 06:27 AM   #6
lfree11012
lfree11012's Avatar
Drives: 2018 1LE
So you are looking for and aux input into the radio. The alpine unit will work you can also you a jl clean sewap or a rockfordfasgate 360.all of there have RCA inputs and there are a few audio contriol unit that do as wall that is if you won't to spend 200 on up of an aux input. But let me toss another Idea at you use a powerd hardware fm mode parts may run 40 max You will need one fm mode and two ant adapters one gm to standert ans a standert back to gm. All of them us RCA sound as long as you a pc with RCA out put you can get it to work for sound as far as using a PC Card for sound q I have never seen one
Old 05-22-2013, 10:28 AM   #7
manu_b
Keeping everything stock, if I install a Rockford 363 or alpine sound processor where would be the ideal location. I don't need loud system, all I need is clarity and I should feel I am immersed in sound, rather then sound coming from doors.
Old 05-22-2013, 11:07 AM   #8
lfree11012
lfree11012's Avatar
Drives: 2018 1LE
They are set up to us aftermart amps bcouse the are trying to give batter sound then stock with an amp the the PDx5 or the punch 10005 it will blow your mind the night and day difference over It keep the stock I would just use the powered fm mode call it a day no point In buying a $600 unit just for an aux input
Old 05-22-2013, 12:31 PM   #9
darkrider01
From what you are asking for here, you would be best served by a JBL MS-8. The 3Sixty.3 would work, but it's going to be much more difficult to set up and tune. The Cleansweep will NOT work as it does not perform time alignment, which you need for the surround effect. The IMPRINT may work, but I have no experience with it.
Best bet is the MS-8. The Logic7 surround processing is pretty sick.
