Old 06-27-2009, 08:42 PM   #1
SSCamaro2010
SSCamaro2010's Avatar
Drives: 2010 Camaro 1ss/rs
Wheel/tire size - Can 315s fit on a 20x9.5 rim ?
Can 315s fit on a 20x9.5 rim??
SSCamaro2010 is offline   Reply With Quote
Old 06-27-2009, 10:17 PM   #2
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
they will fit, but the wheel is not wide enough for best performance. You need a minimum of a 11 inch wide wheel. Plus 315 is too big a tire for the Camaro
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 06-27-2009, 10:34 PM   #3
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
mike
dms
Related question - whats the ideal and minimum wheel width for a 275 tire?
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 06-27-2009, 10:39 PM   #4
novajess1972
I Done Caught Diabeetus.
novajess1972's Avatar
Drives: 1972 Chevelle SS/2010 Tundra
mike
dms
I thought ADM had already confirmed that 315 will go under the car just fine??
http://www.camaro5.com/forums/showthread.php?t=24905
CANCELLED ORDER: 1SS/CGM/MN6/BLACK RALLY STRIPES
novajess1972 is offline   Reply With Quote
Old 06-27-2009, 10:49 PM   #5
Indpowr
Drives: Corvette C6
315s fit fine but the I would not put a 315 on anything less than a 10 IMO and even a 10 is small. Ideal is 11. If you try to stretch a tire that much its much more than performance loss it could be down right dangerous.
Old 06-27-2009, 10:59 PM   #6
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Correct 315s will fit with 11 inch wide wheels. But I second the idea that 11 is the minimum I would use to slap 315s on this car....That is my plan for late this year.
ZZcamaro is offline   Reply With Quote
Old 06-27-2009, 11:03 PM   #7
Indpowr
Drives: Corvette C6
It is my plan as well. Darn tires are costly with now 315s on the wifes car and 345s on mine...LOL
Old 06-28-2009, 12:30 AM   #8
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
mike
dms
So what size do you think?
Yesterday i measured and there is 13.75" in the rear so if you can get a 3 1/2 " lip and a 8" back rim you may be able to run 315 but if not you will have to get the car frame cut 1'" like in the old days that way we get almost 15" in the rear but i will get a 315-325 in this car.
Old 06-28-2009, 12:29 PM   #9
Info@PeddersUSA.com
I know it is a visual and ego thing to get the biggest tires possible. this may be good for drags, but we are finding it actually hinders handling. the Camaro has a big time understeer issue, and doing big tine split configured wheels, will increase understeer and reduce handling, especially if you are sticking with OE suspension.
With that said, 315s can be shoe horned into the rear, making sure you do not go too fat with the wheels. Maybe a 11 to 11.5 max wheel. I know with a 49 offset, you will get some rub, even removing a bunch of the inner plastic fender, and reducing cambers. Maybe a 39-40mm offset may help. But one of the issues is lowering the vehicle with these big meats and being able to set up the suspension for killer handling. For great looks, improved handling, the Camaro needs to be dropped about 1.0 to 1.5 inches or so. This will add to handling more than adding tire.
mike
dms
Old 06-28-2009, 11:42 PM   #10
novajess1972
Geez! What does the wife drive....a Vette?
Old 06-29-2009, 12:17 AM   #11
2SSRS@Gen5diy
mike
dms
Thanks but i new that, If you ask "Deb Basica" you will see that i ordered your camaro Xas in December, And am still waiting for them, and this car is going to be lowered 2 in the rear and 1.0 to 1.5 in the front.
As for visual and ego thing i think i am in good company, But all J/K aside if i go with 275 up front and 315 in rear that is not a big tine split configured setup and did your company not know that this car has understeer issue's is that not why you have your setup.
Old 06-29-2009, 12:51 AM   #12
Info@PeddersUSA.com
Without the Xas the split configurations will cost you maybe .2 to .3gs on a skid pad.
I dropped the the one Camar with 315s, 60mm and had some serious rub, even after cutting the inner plastic out, over bumps. Do you know the rear offsets of the wheels you are getting?
mike
dms
Old 06-29-2009, 12:58 AM   #13
blackedout010
Drives: on order black 2010 2ss
mike
dms
mike, im wanting to run your coilovers and 315's in rear. what offset will be needed as ive pretty much already ordered wheels.
blackedout010 is offline   Reply With Quote
Old 06-29-2009, 01:03 AM   #14
2SSRS@Gen5diy
Not at this time am working with COR and as of Friday not looking good going to try a different offset, If you want send me a pm, How about cutting the inner frame of the car to get 1+ in more on the inside like the old day.
That is the space of the inner plastic to the wheel tub.
Biggest Size Rim? ChevyBoiSS Wheels and Tires Talk Sponsored by The Tire Rack 24 10-10-2008 12:49 AM
