Old 06-29-2009, 10:32 PM   #1
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
Garage Door Programming
Has anyone had any issues with the Garage door controls not working? I finally got around to programming the control- went well- worked the 2nd time (as far as needing to push the learn button on the motor).
Went to work this morning, garage door opened fine. Came home about 12 hours later- door won't open.
WTF???
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 06-30-2009, 08:30 AM   #2
onechuck
Onechuck
onechuck's Avatar
Drives: 2010 Camaro IBM 2SS\RS SC & Cammed
Some newer model garage doors have code jumping on them and this may have something to do with it.
onechuck is offline   Reply With Quote
Old 06-30-2009, 08:32 AM   #3
maxdmax
maxdmax's Avatar
Drives: 2010 Camaro SS/RS
I have 2 garage doors programmed (1 that required the learn button and 1 that did not), I also have an automatic gate programmed on the 3rd button all 3 have and are still working fine for for over 3 weeks. I do remember when we first got my Wife's Tahoe she had issues with somehow erasing one button when she programmed the others, I am not sure what happened but it did. I just did them all at once and they also have wordked great ever since. That was 2 years ago. Do them all over again and make sure they all work and see if that helps.
LPE 417 - TVS2300 787 RWHP 759 Torque - Built by WWW.KYSPEED.COM
maxdmax is offline   Reply With Quote
Old 06-30-2009, 10:01 AM   #4
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I have not had any issues. My garage door required the additional step of pushing the button on the opener itself and then the button in the car ..
Crowley
Crowley is offline   Reply With Quote
Old 06-30-2009, 10:10 AM   #5
BalogUK
THE architect.
Drives: 2SS/RS M6
does anyone know if the camaro got the true HomeLink system or the Lear system that GM has been using in some vehicles?
hope its HL....
#34122 EMPTIED, AT YARD ON 8/26/09; Delivered 9/07/09
MODS: Borla ATAK Cat-Back GFX (#140378), 35% Ceramic all-around, CAI, Inc. Intake w/ Scoop, Hurst Short Throw, Heritage Grille, GM Dove Tail, Laser Interceptor Triple v8.9, Passport Max, Pfadt ZL Stage 2
BalogUK is offline   Reply With Quote
Old 06-30-2009, 10:22 AM   #6
HTWLSS
Camaro Disciple
HTWLSS's Avatar
Drives: Camaro, Chevelle, Corvette...
Send a message via MSN to HTWLSS
Ours does that. So, how do you make Home Link work with that situation?
How the Disciples help Chevrolet and Being a Camaro Disciple
http://modernclassicsauto.com
'68 Chevelle Malibu Coupe; '67 Chevelle Wagon; '99 Convertible Camaro SS #0069; '07 Z06; '06 Silverado Crew Cab 2500 4x4 dually; '14 Sonic RS Hatchback
HTWLSS is offline   Reply With Quote
Old 06-30-2009, 11:02 AM   #7
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Drives: 2SS RS, SIM, 6pd, 20"Alum
Mine has a code but for some reason I didn't need it... it just programmed with the normal remote.
ALSO, you need to hold the button down for a bit longer than your normal remote. Not sure why..but keep the button HELD down. See if that helps.
Embalmer is offline   Reply With Quote
Old 06-30-2009, 11:09 AM   #8
fastball
Banned
Drives: 2017 Camaro 2SS 6MT
If your garage has rolling code technology, be sure to follow the directions in the manual (your Camaro owners manual will have another set of directions in the Homelink section for rolling code). You will know if you have rolling code if you have a learn button on your opener, usually either on the side or by the lights. You have to press that within 30 seconds of syncing up your opener remote to your Homelink in the car.
fastball is offline   Reply With Quote
Old 06-30-2009, 02:55 PM   #9
ravensjeff
ravensjeff's Avatar
Originally Posted by fastball View Post
If your garage has rolling code technology, be sure to follow the directions in the manual (your Camaro owners manual will have another set of directions in the Homelink section for rolling code). You will know if you have rolling code if you have a reset button on your opener, usually either on the side or by the lights. You have to press that within 30 seconds of syncing up your opener remote to your Homelink in the car.
Hmmm, garage door opener was installed approx Oct 2003. How new is the technology? I know it has a learn button- never looked for a reset one.
I thought that the learn button is pressed on the garage door motor unit, and you have 30 seconds to press the Camaro's button (For atleast 2 seconds- and the garage door moves?)
Old 06-30-2009, 03:14 PM   #10
fastball
Banned
Yes, I'm sorry, I meant learn button.... then you have it and it sounds like you did it the right way.
Old 06-30-2009, 03:14 PM   #11
Suskam
Suskam's Avatar
Drives: '11 Camaro/ '02 Grand Prix
I can't get either of our doors to work. I think they are too old ?
Suskam is offline   Reply With Quote
Old 06-30-2009, 03:17 PM   #12
fastball
Banned
You may need to hold the Homelink buttons a few seconds, but older garage doors should work no problem. In fact, the older the easier to match the code, as it's not even a code, its a set frequency that anyone with an RF reader can find and match.
Old 06-30-2009, 03:48 PM   #13
toehead93
Drives: 2014 2SS/1LE
I programmed mine for the community gate entrance. It is set correct because it worked the first three times. Since then it works, maybe 20% of the time. I find it funny that it is the only thing that doesn't work because I joked the first week I had the car how the dome light and remote buttons seem to be the only parts in the Camaro that came from the GM spare parts bin. I plan on having the dealer replace it once I go in for my first service.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 06-30-2009, 04:29 PM   #14
camarossrs2150
camarossrs2150's Avatar
Drives: abm2ssrs
wow didnt even know i had that where is it
[SIGPIC]
camarossrs2150 is offline   Reply With Quote
Need ideas for floor finish and hoist in garage detroitboy 5th Gen Camaro SS LS LT General Discussions 15 01-28-2020 01:05 PM
SITE FEATURE: Camaro5 Owner's Virtual Garage Tran 5th Gen Camaro SS LS LT General Discussions 41 06-15-2009 05:01 PM
Camaro Garage Art. A good idea? cyberbro Camaro Photos | Spyshots | Video | Media Gallery 10 03-27-2009 03:02 PM
Jay Leno sued over sale of roadster in 'sham' auction Wm Holden Off-topic Discussions 4 10-17-2008 03:36 PM
garage? Mrbobcat Off-topic Discussions 5 05-07-2008 08:46 PM
