Old 06-13-2013, 03:54 AM   #1
SIC13ZL1
Drives: 13 AGM M6 ZL1
RATTLING/GRINDING NOISE COMING FROM ENGINE
I JUST INSTALLED MY ROTO-FAB CAI AND WHEN I STARTED HER UP, I NOTICED A RATTLING/GRINDING NOISE COMING FROM THE MOTOR. I NEVER HEARD THIS NOISE WHEN THE OEM AIR INTAKE WAS ON. MY CAR ONLY HAS AROUND 300 MILES ON IT. I SAW A POST ON HERE BY VROOM ABOUT HIS SC GOING BAD AND IT SOUNDS LIKE HIS DID, JUST NOT AS BAD YET. IT SOUNDS LIKE IT IS COMING FROM THE SNOUT, PROBABLY THE ISOLATOR GOING BAD. HAS ANYONE ELSE EXPERIENCED THIS? AM I HEARING THINGS OR CAN YOU GUYS HEAR IT TOO? SORRY FOR THE POOR VIDEO
http://youtu.be/8tT-kxMJzgM
SIC13ZL1 is offline   Reply With Quote
Old 06-13-2013, 04:00 AM   #2
2ss-booya
2ss-booya's Avatar
Drives: 2015 SS Sedan M6
Isolator coupling. It's normal according to GM...
2ss-booya is offline   Reply With Quote
Old 06-13-2013, 04:02 AM   #3
URBAN LEGEND
URBAN LEGEND's Avatar
Drives: 20 X3M CP & 19 ZL1 1LE A10
You are killing me with the all caps!
URBAN LEGEND is offline   Reply With Quote
Old 06-13-2013, 04:53 AM   #4
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
it's still under warranty, take it to the dealer, better safe than sorry.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 06-13-2013, 05:20 AM   #5
PWRHSEZL1
PWRHSEZL1's Avatar
Drives: 2013 Camaro ZL1 #2419
What he said!!! ^
PWRHSEZL1 is offline   Reply With Quote
Old 06-13-2013, 02:31 PM   #6
Vroom
That's how mine went too. It started right after I changed the air filter. get the sound on video, which I know is pain since its sporadic, and take it in. they'll have it replaced in a couple days.
  • 2013 Victory Red ZL1 - 210K+ miles. Mods: Who needs mods...its a freaking ZL1 - Last car: 2006 GTO
Vroom is offline   Reply With Quote
Old 06-13-2013, 03:09 PM   #7
HDRDTD
IIRC, The isolator does normally make 'some ' noise by design.
If the noise is 'excessive' they will replace the entire SC assembly and not just the isolator because the entire unit is considered a replacable unit.
Who determines if the noise falls within normal limits or is considered excessive? Good question
Old 06-13-2013, 03:27 PM   #8
KKreme15
KKreme15's Avatar
Drives: C6 Z06
RIP to your supercharger
gone but not forgotten
Everyone go pull your S/C and clean the oil out, then install a catch can!
The oil build up will mess with the bearings/rotors and eventually cause your s/c assembly to make nasty noises and maybe fail!
KKreme15 is offline   Reply With Quote
Old 06-13-2013, 04:32 PM   #9
#737 ZL1
Drives: 2012 ZL1
I listened to vrooms video and in my opinion your motor sounds nothing like his. His you could hear the hard grind, I don't hear that in your video. what I hear in your video is exhaust and upper motor warm up?
#737 ZL1 is offline   Reply With Quote
Old 06-13-2013, 05:23 PM   #10
DangerZL1
Drives: 2023 Black ZL1 Auto
I listened to the video, and my previous 2012 sounded exactly the same. It sounds like the coupler noise (marbles rattling in a can), not the squeeling of a bearing or some other part failure within the supercharger as heard in another video. I hated the noise and heard it since the car was new, but it didn't get any louder with my RotoFab. I didn't worry too much about it, since I planned on changing the upper pulley and going to a solid coupler.
DangerZL1 is offline   Reply With Quote
Old 06-13-2013, 06:44 PM   #11
Vroom
his sounds about right. it's very hard to capture. in his video you can hear the slight squealing at the start of the video. most the time mine would sound just like that at startup and it was so subtle I couldn't ever catch it before it disappeared behind the isolator noise. took a week to capture the noise in the video.
the noise sounds horrible, and it will get worse, but I don't think it's going to hurt anything. I also had a slight surging as the car would settle to a constant speed after accelerating that only I noticed.
Old 06-13-2013, 08:13 PM   #12
SIC13ZL1
Thanks guys for all of your input and opinions. I made an appointment with my dealer just so they could check it out and give me some piece of mind. Just want to play it safe. I'll let u know what the outcome is.
Old 06-13-2013, 08:32 PM   #13
OldScoolCamaro
...there are several threads on this noise issue that has been an ongoing concern...Eaton,... the manufacturer, decided to place a spring in the coupler for God knows why, which is less than a precise coupling and causes wear over time causing a harmonic noise. It's normal actually, by all accounts. I am not a fan of this poor design.
Old 06-13-2013, 08:36 PM   #14
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
When you go in for this problem do you leave the CAI installed so they can hear it better?
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
2013camarozl1, camarozl1, musclecars
