Old 06-18-2013, 12:21 AM   #1
Khmero215
Khmero215's Avatar
Drives: Victory Red 2SS
help with rim size
if the size is 20x9 +35, what does the + 35 mean? I just wanna buy the right rims
Khmero215 is offline   Reply With Quote
Old 06-18-2013, 12:22 AM   #2
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
35 is the offset
CHMSC is offline   Reply With Quote
Old 06-18-2013, 12:31 AM   #3
Khmero215
Khmero215's Avatar
so the offset in the front should be different from the back? or ok to be the same all around
Old 06-18-2013, 12:37 AM   #4
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
It depends on the size you are getting. For instance here is what our SS comes with stock
SS front 20x8 +35mm
SS rear 20x9 +40mm
You can run a square set up all around so you can rotate tires or for better handling. What are you trying to do man?
For instance I bought a second set of stock wheels so I could run 20x9 wheels all around and 275 tires all around.
Old 06-18-2013, 12:45 AM   #5
Khmero215
Khmero215's Avatar
I just want to buy new rims but use the tires from my stock wheels
Old 06-18-2013, 12:51 AM   #6
Khmero215
Khmero215's Avatar
like would I be able to do 20x9 +27, 20x10 +35
Old 06-18-2013, 01:05 AM   #7
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Yu should really put new front tires on at the least. If I were you contact one of the vendors on here to help you out. They know all the offsets that work for you car.
A few of them would be Tony at dv8customs, Mike at bestwheeldeals.com, mod bargains, etc
Old 06-18-2013, 07:33 AM   #8
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
Khmero215, to educate yourself about wheels and offsets, take a look at the thread at the top of the section in the "stickies"
OFFSETS
Old 06-18-2013, 08:59 AM   #9
Khmero215
Khmero215's Avatar
thank you!!! cleared it all up
