![]() Drives: 2010 Camaro 2SS IBM Join Date: Apr 2009
I was curious, with the issues that some people are having with the L99 and slower than expected 0-60 times, I read thru my manual carefully to get the Competition Mode sequence correct.
I read in a few threads that some were saying to put it into Comp Mode that you have to hold the TC button down for 7 sec. but no where in the manual does it say this. The manual says to press the TC button 2x to turn off traction control and this puts it into Comp Mode which should show up on the DIC panel. Can someone please clarify where the 7 second button hold comes from and what is the correct way to put the car into Comp. Mode. ![]() ![]() Thanks Guys
Event 1100 - 4/2/09 ![]() Event 2000 - 4/6/09 ![]() Event 3000 - 4/10/09 ![]() Event 3300 - 4/27/09 ![]() Event 3800 - 5/12/09 VIN#9436 ![]() Event 4200 - 5/18/09 :party0038: Event 5000 - 5/28/09 delivered ![]() |
TBoy
Danny
Holding the button for 7 seconds turns off both Traction Control and Stabilitrak. Hitting the button twice puts you in Competition mode where I believe Traction Control is off and Stabilitrak is relaxed (not off, but not fully on).
2SS/RS CGM with black rally stripes
DON_RAFA describing my Noweeds cutouts - "Very Strong. When I couldn't see you I still heard you. Sounds like your car is pissed at the world." |
So which do we think is best on trying our 0-60 times. Those that had issues never mentioned putting it into only the Comp mode but they did do the 7-sec. hold to turn everything off. Could this make there times better by running in the Comp. mode. But maybe they did and I just misunderstood.
Thanks
#5 | |
#6 | |
i've read where running in COMP MODE (2 clicks of the button) has saved someones tail in a corvette because the track had an unnoticed wet spot from the previous car. when the vette hit the wet spot under full power it wanted to get sideways but the stabilitrack helped save it. if your car gets sideways.... you could care less about your timed run. stabilitrack is no guarantee... but im sure it helps avoid getting squirly! just my .02
Why oh Why?
Windshield=10" vertical mirror= 3 7/8" (that's almost 4") vertical that means that the mirror is 38.75% the size of the vertical windshield... it sure seems like the ratio could be better... just sayin.... ![]() our collective MIRROR patch: http://www.camaro5.com/forums/showthread.php?t=24612 |
#7 |
Danny
I think having either Competition mode or both off will give the best 0-60 times. In both modes, TC is off.
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: The Imperial Army Join Date: Feb 2009
#9 |
![]() Drives: C6 Zed-oh-six Join Date: May 2009
you dont have to hold anything for 7 seconds, I just push the button to turn the TC off and then press it again quickly twice and the DIC will read Competition Mode
#10 |
hmmmmm
Drives: 2010 IOM in-n-out 2SS Join Date: Oct 2008
be carefull in the all off mode, I tried this and it really really get sideways easy and fast.
"Responsibility is a Heavy Responsibilty" (Cheech)
#11 |
I put the FU back in FUN
Drives: 1969 SS 396 , 2010 Camaro SS Join Date: Jun 2009
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
No, what they're saying is if you hold the TC button down for 7 sec, it will turn everything off (the TC and Stability). If you push the TC botton quickly twice, it puts you in Competitive mode. Competitive mode turns off TC but partially leaves on Stability. That's what I've been reading from guys. So supposedly theres a difference between competitive mode and the 7 sec (everything turned off) mode. ![]() So far, I've just been using D (drive), M (Sport), and M (tap shift) with TC on and off. I haven't tried Competitive mode or the 7 sec (everything off mode) yet. |
#13 |
![]() Drives: 2SS/RS, 6spd, IOM, blk hockey Join Date: Jun 2009
#14 |
| L99 (best mode for racing?) | SGOS252382 | Dragstrip and Launch Techniques Discussion | 20 | 03-17-2013 08:49 AM |
| Advise on competitive mode?? | stratman2SSRS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 05-27-2009 09:59 AM |
| Auto Users, use the M mode and not paddles!! | Scott@Bjorn3D | 5th Gen Camaro SS LS LT General Discussions | 19 | 05-14-2009 02:44 PM |
| COMPETITIVE MODE AND LAUNCH CONTROL (V8) DIRECTIONS | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 80 | 05-02-2009 12:20 PM |
| The New KITT car redesigned again.(VERY HIDEOUS!!) | Camaro Man | General Automotive + Other Cars Discussion | 54 | 07-30-2008 04:49 PM |
