![]() Drives: 2013 Camaro ZL1 Join Date: Jun 2013
ZL1 Black Rim Wax
Is it safe to wax these rims with wax?
Camaro SL,UTs
Drives: 2010 Camaro SS/RS #16429 Join Date: Sep 2006
They are just painted with a clear coat on top. YES. Make sure the wax you use is clear coat safe. But with any wheel, make sure they are cool before you put anything on them. And for your own good test whatever product your going to use in a small area just in case
it's mind bottling..
Drives: SGM Join Date: Apr 2011
You should use a sealant instead of a wax.
![]() ![]() ![]() ![]() ![]() ![]() Drives: SS 1LE Join Date: Nov 2012
I have waxed mine with adams wax.
Drives: The shiny ones. Join Date: Mar 2010
Our Quick Sealant is ideal for wheels, for a few reasons:
#6 | |
![]() ![]() Drives: Camaro rs 2lt IBM Join Date: Apr 2012
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: SS,PaceCar,ZL1,1LE,C7Z51,Z06,17-ZL1 Join Date: Jun 2009
![]() Use it on mine too!!
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 IOM Vin #169 Join Date: Jan 2011
Becky did you take the tires off to apply the sealant, and do you know how much the torque is needed to place the lug nuts back in place? TY
#9 |
i didnt take tires off, its very easy to apply, and i believe its 140lb/ft
#10 | |
Drives: ... Join Date: Apr 2009
You can have your service dept. check it out, if they question it have them look up doc id 2210980. You can possibly warp the rotar if you set it at the 140lb/ft |
#11 | |
![]() Drives: ZL1 Join Date: Jun 2013
Greg
#12 |
Torque on ZL1 wheels is 110 lbs. Its in the owners manual.
#13 |
![]() Drives: Black 2013 2SS/RS 1LE Join Date: Mar 2013
I found it somewhere to be 110#
