Old 08-13-2013, 09:52 PM   #1
bigssc
Drives: Black 2013 Camaro 2SS (auto L99)
maintenance question
when should i do my first tranny flush/rear end flush and coolant flush and tire rotation? i only have 2,200 miles on the car but i just want to be prepared. i tried and didnt really find the answer. i probably just didnt look in the right place though.
bigssc is offline   Reply With Quote
Old 08-13-2013, 10:05 PM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
I have 185000 miles on my expedition..bought it new...have never changed any fluid other than oil every 5000 miles...it still run,drives like new...no time set to change the fluids ...rotate tires every 10000 miles ....I plan on driving it til the wheels fall off
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 08-13-2013, 10:07 PM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
no manual?
Glen e is offline   Reply With Quote
Old 08-13-2013, 10:11 PM   #4
bigssc
Originally Posted by Glen e View Post
no manual?
ill check the manual but i was on my computer so i figured id ask the camaro5 gurus since im in my house for the night lol
Old 08-13-2013, 10:12 PM   #5
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
Some change the trans and differential at 75000 to 100000 miles, I change mine at 100000. When you have the transmission fluid changed have the filter changed to. Like another poster stated tires can not be rotated.
If you have not change the oil do it now then every 5000 miles
(edited to change tire can be rotated side to side but not from front to rear)
Caddy
Caddyroger is offline   Reply With Quote
Old 08-13-2013, 10:16 PM   #6
bigssc
cool thanks, and yeah i changed out the crappy factory oil at 1,900 miles for royal purple.
Old 08-13-2013, 10:24 PM   #7
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
Read your owners manual, search and read this forum a lot more. Stock Pirelli's on an SS or RS are not directional and can be swapped side to side per 2012 manual and probably 2013, check it out. They are marked on the outside as outside. So when you swap sides the outside is still on the outside, the tire will rotate in the opposite direction which is fine. I do mine every 8K. Looks like I should get at least 30K out of them, got 17K on them now and they look good.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 08-13-2013, 10:35 PM   #8
Bonanza7
Drives: 2010, Rally Yellow, Black stripes
I had my rear end drained and re- filled at about 6000 miles. Dirty and lots of debris.
Bonanza7 is offline   Reply With Quote
Old 08-13-2013, 10:41 PM   #9
myold88
myold88's Avatar
Besides regular oil changes, I also had the Rear end fluid changed on my '10 SS
at 17,000 miles. Both the fill & drain magnetic plugs were loaded with
filings- (looked like silver paint.)
Old 08-13-2013, 10:45 PM   #10
Alot9439
Alot9439's Avatar
Drives: 2SS RS
will it depends on how you drive ( severe use, etc) I make a habit of changing my deferential fluid every 35k because I did to drive quite aggressively I also change the trans fluid every 50k. I see it as better safe than sorry.
Alot9439 is offline   Reply With Quote
Old 08-14-2013, 06:28 AM   #11
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Yes... they can. If they are the stock RS staggered wheels/tires (Pirellis, for example) they can be rotated side to side. DO NOT perform typical rotation of front to rear/side to side. Fronts stay on front - rears stay on rear. And this rotation will help tires wear more evenly and last longer.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 08-14-2013, 07:37 AM   #12
ssrs2lt
ssrs2lt's Avatar
Drives: too many
all tires rotate duh! JK
ssrs2lt is offline   Reply With Quote
Old 08-14-2013, 08:56 AM   #13
Blue-J
Blue-J's Avatar
Drives: 2013 2LT HWSE
While in the house on your computer.
http://www.chevrolet.com/content/dam/Chevrolet/northamerica/usa/nscwebsite/en/Home/Ownership/Manuals%20and%20Videos/02_pdf/2k13camaro1.pdf
https://assets.gm.com/manuals/chevrolet/2013_chevrolet_camaro_navigation.pdf
Enjoy your ride.
Blue-J is offline   Reply With Quote
