Old 08-16-2013, 04:46 PM   #1
Khmero215
Khmero215's Avatar
Drives: Victory Red 2SS
supercharged cars
should I use different oil since I'm supercharged? currently using 5W-30
Khmero215 is offline   Reply With Quote
Old 08-16-2013, 05:34 PM   #2
LS3 SS
Drives: 2010 Cyber Grey Camaro SS (LS3)
It wouldn't hurt to go with an oil that has more ZDDP (high zinc content) to protect your valvetrain and other components from high heat and wear. Amsoil, Valvoline, Joe Gibbs all make higher zinc content oils, for a higher price of course.
LS3 SS is offline   Reply With Quote
Old 09-05-2013, 04:28 AM   #3
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
and change it more often. it will get dirty much quicker with the blow by.
JCunningham is offline   Reply With Quote
Old 09-12-2013, 06:00 PM   #4
Piccione Performance
Piccione Performance's Avatar
Drives: 2010 2ss/rs & 2014 Stingray
It depends on how much boost your running, for you area I would at least run 10w30.
We have a much hotter climate out here, we run 5w50 in the 8lbs of boost or less, and 15w50 over 8lbs of boost.
Piccione Performance is offline   Reply With Quote
Old 09-20-2013, 01:26 AM   #5
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
I run Valvoline VR1 Syn 20w50, it is a high zinc formula and works great for me. Get used to your taking a while to warm up though, takes about 10 to 15 minutes before your car wants to play ball.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
