Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Interior Parts & Accessories
Old 08-16-2013, 04:47 PM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
2010-2013 Camaro Hydro Carbon Fiber Interior Door & Dash Panel Inserts RPI Designs
2010 2011 2012 2013 Camaro Hydro Carbon Fiber Interior Door & Dash Panel Inserts
Our fiberglass door panel inserts actually replace your oem pieces. Simply remove your stock door panel and replace with these. These are sold in a set, one passenger Camaro door panel insert and one driver Camaro door panel insert. These are for non-ABL cars (cars without lighting in the doors).
Our dash panel inserts are GM pieces that we take brand new and paint your exterior body color.
Please select color option below. These are custom painted to order so please allow additional time to ship.
These are sold in a set and will fit any 2010-2013 Camaro including RS, SS and ZL1.
2pc door panels
4pc door and dash
2pc dash only
use coupon code LANA5 and receive and additional 5% off the price
website link http://www.rpidesigns.com/shop/item.aspx?itemid=3133
RPIDon is offline   Reply With Quote
Old 08-21-2013, 09:44 PM   #2
zer0ss
zer0ss's Avatar
Drives: 2012 Camaro V6 LFX
Does this include the mounting hardware?
Darkheart Build thread
Mods: CAI Intake w/ Scoop and Rotofab WW Relocation, MRT v2.0 Exhaust, RX Catchcan and Ported TB
Appearance: AAC Ghosted Side markers, Plasti-Dipped Bezels and 'Beauty Rings', Fully Debadged, Tinted Tail Lights and Reverse Lights
Sound: Two 12" Kicker Comp Subs in ******** Enclosure
zer0ss is offline   Reply With Quote
Old 08-22-2013, 09:50 AM   #3
RPIDon
RPIDon's Avatar
Drives: Camaro
Thank you for asking, it uses the stock GM hardware that is holding the old panels on, just remove and replace. Thanks, Don
Old 08-25-2013, 04:52 AM   #4
zer0ss
zer0ss's Avatar
OEM door panels are held in with "melted posts" a cheaper alternative to pop rivets. GM has a part number for the specific 8mm and 15mm hardware to be used once the door panel has been removed.
Stolen from another thread:
(2) 15mm long screws (small flange pan head)
(26) 8mm long screws (large 1cm flange pan head, no point)
Or are ABL door panels and non-ABL mounted in differently?
Old 08-27-2013, 10:41 AM   #5
RPIDon
RPIDon's Avatar
Drives: Camaro
good illustration thank you for posting it zerOss, The abl door panel kits do come with the hardware , it is the non abl pieces that do not come with the hard ware that you will have to get locally. Thanks, Don
Old 09-03-2013, 06:33 AM   #6
mikey1107
mikey1107's Avatar
Drives: 2017 SS
Are there any pictures of the white carbon fiber?
Sent from my iPhone
2017 SW SS
mikey1107 is offline   Reply With Quote
Old 09-03-2013, 01:39 PM   #7
RPIDon
RPIDon's Avatar
Drives: Camaro
Hi Mikey1107, I will see what I can come up with. Thanks, Don
Old 10-31-2013, 06:42 PM   #8
mikey1107
mikey1107's Avatar
Drives: 2017 SS
Pics of white yet?
Sent from my iPhone
2017 SW SS
Old 10-31-2013, 06:57 PM   #9
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
Originally Posted by mikey1107 View Post
Pics of white yet?
Sent from my iPhone
+1 I'd like to see that as well.
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 11-04-2013, 12:40 PM   #10
RPIDon
RPIDon's Avatar
Drives: Camaro
Thank you for the interest, we have a customer that just ordered a set in white and he will send me the photos to post when the installation is done. So hang in there.
Old 11-04-2013, 05:25 PM   #11
Behic2320
SoCal HT5 COTW 4/21/13
Behic2320's Avatar
Pics of white yet?
Sent from my iPhone
Where is that darn customer….
Oh wait a second…
Im just waiting on the pieces guys and I will install them ASAP
Old 11-08-2013, 09:42 AM   #12
Ryanbabz71
Ryanbabz71's Avatar
What dash panels do you have hydro dipped? Do you supply the part or would I?
Ryan
Ryan
Old 12-06-2013, 11:34 PM   #13
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Do you or plan on offering these with ABL?
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 12-10-2013, 03:33 PM   #14
RPIDon
RPIDon's Avatar
Drives: Camaro
Good question and yes we can, the price would be $389.95, if you would like to get them please give me a call at 888-257-8515 ext 2. there is not an option on the website for this. Thanks, Don
