Old 09-02-2013, 07:40 PM   #1
VINNY1980
VINNY1980's Avatar
Drives: 2010 camaro 2ss abm m6 , 2013 zl1
Send a message via AIM to VINNY1980
Ls7 clutch
Can i just get a ls7 clutch from a vette or do i need to change flywheel and everything. Thanks its a 2010 camaro ss ls3.
VINNY1980 is offline   Reply With Quote
Old 09-02-2013, 08:25 PM   #2
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
Don't do it, I put a ZR1 clutch in my car and it lasted 3 passes, they just are not set up for the weight of our car. I went with a Street Slayer Twin Carbon, well worth the money and rebuildable.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 09-02-2013, 08:50 PM   #3
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
The clutch in this car is the same clutch as ls7.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 09-03-2013, 05:25 PM   #4
Steve@SNL/Monster Clutch
Drives: 2014 SS
Agree with the above, how much power are you making?
Steve@SNL/Monster Clutch is offline   Reply With Quote
Old 09-04-2013, 12:46 PM   #5
H-E
Drives: 2010 zr1 Camaro 2011 vert
I wouldnt spend my money on a stock replacement, any single for that matter....since you need a clutch what are your hp goals for the car? I can promise you it will be cheaper to do it right the first time. If we can help you out give us a call.In the mean time check out the reviews on the Street Slayer, a clutch built for the 5th gen camaro.
H-E is offline   Reply With Quote
Old 09-04-2013, 02:23 PM   #6
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
The street slayer is a great clutch from what I hear, I personally have an ACT twin in my car and can tell you that it has been great as well. Whatever brand you decide to use, you should be going for a multiple disc clutch, there's no comparison.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 10-01-2013, 10:31 AM   #7
VINNY1980
VINNY1980's Avatar
Don't really know how much power just got it had for about a month now. It has headers and intake tune hi flow cats and atak exhaust. Just noticed that it releases a little high. And I'm not cheap I just want to so once. I work on transmissions for a living so the r&r is the easy part thanks Tom
Sent from my iPhone using Tapatalk - now Free
Old 10-01-2013, 11:01 AM   #8
VINNY1980
VINNY1980's Avatar
Ls7 clutch
Double post
