Old 09-18-2013, 03:03 AM   #1
6bangerBOOM
6bangerBOOM's Avatar
Drives: 2016 1SS SW
Help me make this work!!
I'm installing a Zex system this week (installed the bottle tonight) and I'm trying to figure a good spot for the switches. I had an extra set if dash trim leftover from my last upgrade and thought it would be awesome to mount the arm switch and bottle opener switch on the dash trim to left of the steering wheel. It looks bad ass, but looking into space behind the trim piece there is no room for the switch itself to fit.
Front face:
I need a switch that is shorter on the back side that will fit inside the dash trim and fit with an airplane switch cover. It's not the biggest deal (I'm mostly excited about nitrous) but I think it would look too cool.
6bangerBOOM is offline   Reply With Quote
Old 09-18-2013, 03:18 AM   #2
6bangerBOOM
Drives: 2016 1SS SW
Pic of the back side:
Old 09-18-2013, 08:46 AM   #3
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Yea, you're not going to be able to mount the switch there unless you cut it open or something. I wanted to mount switches there too but after seeing that there is no space there, I had to change it.
Old 09-18-2013, 01:30 PM   #4
6bangerBOOM
Drives: 2016 1SS SW
I'm thinking about making a small sheet metal box that I could mount there. Nothing that sticks out too far, but enough to allow clearance for the switches. Im going to pick up some 90 degree disconnects as well. Also, I'll paint it black and put white stripes on and hit with a coat of clear. Hopefully it'll look good, cuz I don't want to give up on this spot.
Old 09-18-2013, 04:43 PM   #5
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
I do not like cutting into my car.
Old 09-18-2013, 05:58 PM   #6
6bangerBOOM
Drives: 2016 1SS SW
It's as scary as it is satisfying.
Old 09-18-2013, 07:08 PM   #7
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
You can mount a switch there, I bought a small round Sw.from AutoZone, I had to trim the leads, but it fits.
gutterball is offline   Reply With Quote
Old 09-18-2013, 10:52 PM   #8
6bangerBOOM
Drives: 2016 1SS SW
Where did you run the wiring behind that? I'm thinking I'm going to drill in between the bolt and the hole that the left tab fits in.
Old 09-19-2013, 01:02 AM   #9
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
Are you left or right handed?
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 09-19-2013, 08:27 AM   #10
gutterball
gutterball's Avatar
I did drill a small hole and feed the wire down.
Old 09-19-2013, 08:33 AM   #11
gutterball
gutterball's Avatar
Both
Old 09-19-2013, 01:23 PM   #12
SIXJAK
SIXJAK's Avatar
Both
Have you sat in your car and reached out with either hand to a spot that feels comfortable and makes sense to YOUR brain. Wherever that spot is in your car is where that switch needs to go. From there the trick is making it look like it belongs there.
Old 09-19-2013, 04:19 PM   #13
gutterball
gutterball's Avatar
That's my sw. for the fog lamps, so no big deal.
Old 09-19-2013, 04:33 PM   #14
mc_acoustic
Drives: 2010 1LT Limited Edition Camaro A6
Just get a smaller switch man!
Its a decent idea and placement.
2010 Camaro Synergy Green Edition V6/A6: Cold Air Inductions Intake, Trifecta tune, BBK long tube headers and Hi flow cats, MRT V1, Ported Throttle Body, Stage 4 Ported Intake Manifold (MACE), Black Ice-olator Intake Manifold Spacer, Plenum Spacer, Nytrex Triple Threat Nitrous.
mc_acoustic is offline   Reply With Quote
