Old 09-29-2013, 10:51 AM   #1
ShadowFX
Drives: 2014 2LT Blue Ray Metallic Conv.
I can't dry my car... :o\
Hey guys, just bought my first camaro 2014 2LT Convertible (actually have had it for a month now, but haven't gotten around to posting it).
I've been meaning to do a good photo shoot for my new baby, but I've tried to wash it twice now and I can't seem to dry it. I know, it sounds weird but I've tried two different chamois and it just smears the water and is leaving water spots/smears all over the car! I've washed several cars by hand before using the same chamois (Absorber) and I've never had this problem. I'm wondering if it's because it's new and if the protective coating (Perma Plate?) they put on at the dealership is causing it. I'm ready to just pay to take it to a professional detailer, but wanted to see if I could get any advice here.
Please help me so I can do a well over due photo shoot for my baby!
ShadowFX is offline   Reply With Quote
Old 09-29-2013, 12:01 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
You should have never let your dealer apply anything.
But as for what to do now, try to put a coat of wax on it and see if that helps.
Sent from my HTC One using Tapatalk 2
[B]
Old 09-29-2013, 12:23 PM   #3
Ryanbabz71
Ryanbabz71's Avatar
you need one of these, just blow the water off your car
http://www.autogeek.net/metro-full-size-vac-n-blo.html
Ryan
Old 09-29-2013, 12:45 PM   #4
LikaRokBowTie
Drives: 221SS1LE
Maybe the dealer applied it as an add on to jack up the price,anyway see if it can be stripped with a dawn wash or any of the other numerous strip wash products available.You should start with a clean surface clay,wash,polish and seal or wax.All you need to know is in this section.
LikaRokBowTie is offline   Reply With Quote
Old 09-29-2013, 12:56 PM   #5
Ohten
Ohten's Avatar
Drives: Granite Crystal Challenger SRT
I Agree also I would never let a dealer apply anything to a new car.I dont even let them wash it when I buy it or if it is in for service.
Ohten is offline   Reply With Quote
Old 09-29-2013, 01:11 PM   #6
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
Have you tried any of the microfiber drying towels on the market?
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 09-29-2013, 01:49 PM   #7
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2019 ZL1 on Order
Also - use the sheeting method to get most of the water off before you even get out the drying towels
Modern07 is offline   Reply With Quote
Old 09-29-2013, 10:10 PM   #8
Fish-man
Drives: too many to say!
This
Turn the hose on low, without nozzle... slowly go over the car
Fish-man is offline   Reply With Quote
Old 09-30-2013, 12:51 AM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Dry the car the best you can then go back over the entire car with detailing spray and a GOOD microfiber towel.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-30-2013, 01:16 AM   #10
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
The chamois is great. Try going over the car with a rubber sgueegie first. It removes most of the water and then you go over it with the chamois and it's dry. Don't buy compressor. No offense, but as great of an idea it is, you can do the same thing with a $30 shop-vac. Def. go over it with detailing spray and a good microfiber.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 09-30-2013, 07:28 AM   #11
CamaroDreams07
Drives: Slow V6
Please don't do this.
[B]
Old 09-30-2013, 08:13 AM   #12
molsonbrador
molsonbrador's Avatar
Drives: 2010 Camaro SS, 2018 Colorado
I bought a Dry Me Crazy towel after reading CD07's review. I laid it on the roof and it just about sucked the water out of the lug nut holes! It's THAT good. Pulls water like nothing I've seen. Those blue MF towels are sweet too.
molsonbrador is offline   Reply With Quote
Old 09-30-2013, 08:20 AM   #13
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
Electric leaf blower.Wash and dry in the shade.
its a syn is offline   Reply With Quote
Old 09-30-2013, 08:33 AM   #14
motorhead
Do not use a Chamois. That's an old school way of putting swirls in your paint. Like others have said, use a quality microfiber towel with a good detail spray. I usually use two every time I wash mine. one to get the really wet off and then a dry one with detail spray to finish.
2014, detailing
