![]() Drives: 2018 SS - 2015 SS 1LE - 2013 SS Join Date: Aug 2013
Oil Change Tools
Hello all. I only put 4000 miles on my 2SS for its 1st season. I have yet to look at my car on oil change areas. Before I give my 1st oil change on my Camaro for storage, is there any special tools I may need to properly disconnect parts for the self service?
Thanks for the help!
Billy B.
Current: 2018 Hyper Blue SS |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
Ramps to drive your car on or Lift
Oil catch device Rags Rubber gloves to keep your hands clean 15mm socket (I use a gear wrench) 3/8" ratchet Extension I use this type of oil filter removal (use with the extension and ratchet) http://www.fcpeuro.com/products/oil-...FctAMgodnyYAJw Oil and Filter
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
![]() ![]() Drives: 2010 SS Join Date: Aug 2006
If you want to make a 70 mile drive south I'd be happy to show you, best part is I have a lift.
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
#4 | |
Billy B.
#5 | |
What type of lift do you have? I'm wanting to install one when we build another home with a pole barn.
Billy B.
#6 |
If you havent clear coated it yet I would highly suggest doing it
Ryan
#7 |
I did and I used two packs of the anti slip crystals. Came out great! It really sucked having my Camaro sit outside for 4 days though!
Billy B.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 LS M6, Black Join Date: May 2009
Make sure to use a 6-point socket. Twelve point sockets are for the birds.
Don't use an oil filter wrench to put the filter back on! It only needs to be hand tight, and typically, you shouldn't need to use a wrench to get it off, either. John B.
1995 Mitsubishi Montero SR 1987 Dodge Raider Turbo Project 1986 Mitsubishi Montero 2.4l FI Transplant |
