Old 10-01-2013, 04:20 PM   #1
Kiteboarder85
Kiteboarder85's Avatar
Drives: 2018 SS - 2015 SS 1LE - 2013 SS
Oil Oil Oil, which to chose?
Changing my oil for the first time is coming up towards the end of October before storage. Yes, I can search other threads, but a forum is for small talk isn't it?
Whats the best oil I should chose for my SS oil change? Is it Mobile 1? Also, which type of oil filter is best?
Billy B.
Current: 2018 Hyper Blue SS
Kiteboarder85 is offline   Reply With Quote
Old 10-01-2013, 06:55 PM   #2
mliebs
mliebs's Avatar
Drives: 2022 ZL1
After reading a million threads about it I think I'm just going to go with Mobil 1. I used it in my Vette's and never had any issues so I think I may just stick with what I've used before. I change my oil every 5000 miles and 75% of my miles are on the freeway so I'm not sure some of the real expensive oils would even be worth it. Anyway, that's my 2 cents.
mliebs is offline   Reply With Quote
Old 10-01-2013, 08:36 PM   #3
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
I have been using Pennzoil Platinum, Ive noticed it keeps the valvetrain a little quieter. Mobil 1 is good, I use to use it... may start using it again. For a filter? Wix all the way!
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 10-02-2013, 12:11 AM   #4
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Valvoline VR1 Synthetic here, works well, but takes a long time to get warm with it.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 10-02-2013, 07:04 AM   #5
Scott@Bjorn3D
Pennzoil Platinum here.
Scott@Bjorn3D is offline   Reply With Quote
Old 10-02-2013, 12:35 PM   #6
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Alternate Amsoil Dominator 15w50 then Amsoil Zrod 20W50.
On my wifes 2 V6 5th gens wix filters with Pennsoil Ultra 5w30
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 10-02-2013, 02:22 PM   #7
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
Schaeffer Oil: #9003 Supreme 9000™ Full Synthetic SAE 5W-30
#9003 Supreme 9000™ Full Synthetic SAE 5W-30 is recommended for use in all gasoline fueled automobile and light duty truck engines including those that are turbocharged and supercharged. #9003 is API SN, Resource Conserving, ILSAC GF-5 and GM dexos-1™ Compliant.
TD Sheet:
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 10-02-2013, 02:53 PM   #8
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
I am trying out Mobil 1 ESP 5w-30, which is built for the European market and is Dexos 2 approved. It has an HTHS of 3.5 so it should take some pounding, but it is low in ZDDP which may or may not be critical for this engine. I sent in an oil analysis for my Pennzoil Platinum to use as a base line.
wakespeak is offline   Reply With Quote
Old 10-02-2013, 02:57 PM   #9
Avenging Orange
Avenging Orange's Avatar
Spin the big wheel of oil. Most all major brands (dino, semi and synthetic) will do well. The key is regular changes. As for filters, most are good as well, but I'd steer clear of fram..
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 10-02-2013, 03:44 PM   #10
Mouse6.2
Mouse6.2's Avatar
Drives: 2013 2SS/RS M6 NPP
Any of the dexso1 oils and 5k oil changes and sleep well.
When was the last time anyone had an engine go bad due to the oil causing the problem? Besides, most don't keep their vehicles long enough to make a difference.
Mouse6.2 is offline   Reply With Quote
Old 10-02-2013, 10:58 PM   #11
1Slow6.2
1Slow6.2's Avatar
Drives: 2013 1LE camaro
I use pennzoil ultra! With a K&N synthetic filter. So far so good. According to the onstar monthly report it's not due for a change until 15k and i put the ultra In at around 8k
If you're reading this objects In side view mirrors are losing as I'm rowing the 3:91's
1Slow6.2 is offline   Reply With Quote
Old 10-08-2013, 09:22 AM   #12
Vipercar
Vipercar's Avatar
Drives: 2010 IOM 2LT/RS
Question about oil. A mechanic friend of mine has suggested I check out an oil called Motul. Does anybody here have any personal knowledge of this product. I have not even seen this product mentioned on this forum.
Vipercar is offline   Reply With Quote
Old 10-08-2013, 10:06 AM   #13
wakespeak
wakespeak's Avatar
Here is my oil analysis report from BlackStone. Pennzoil Platinum 5w-30, PF48 AC filter, and AC ZL1 air filter. The ZL1 air filter offers more flow but was concerned until this report that it might let in more dirt.
Old 10-08-2013, 10:21 AM   #14
wakespeak
wakespeak's Avatar
Motul is popular in Europe like Castrol, but looks today a little overrated. Check out www.bobistheoilguy.com. Any oil that meets ACEA A3 (a European rating) is designed for high performance driving and typically has high film strength relative to other oils. If you have the V-6, an oil like that could help as a Mercedes study I saw indicated that a lot of the intake valve deposits were from the viscosity improvers in the oil. A3 rated oils I would say have synthetic base stocks that require very little if any viscosity improvers.
