Old 10-31-2013, 11:12 AM   #1
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
HP ratings and weight for 1LE driveshaft and axles???
The 1LE was advertised as having a beefed up driveline.....if that implies the driveshaft and axles.....IF.... what are they rated at for hp handling?
ie 1000hp or 1400hp? less?
I'm looking at adding some strength for peace of mind AND reducing rotational mass/weight at the same time.
I want to make sure it's worth it...... if the 1LE already HAS 1000hp alxes and/or driveshaft...not sure I'll drop that much $ to reduce a few lbs.
Can someone "in the know" CONFIRM or somehow show proof of the hp ratings of the 1LE OEM driveshaft and axles?
I'd like to know their weight as well if someone has removed and weighed so I can determine if the money spent is worth the drop of weight. Thanks guys!
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 10-31-2013, 11:19 AM   #2
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
I thought the 1LE used the same axles as the ZL1, driveshaft I think is standard manual SS.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 10-31-2013, 12:05 PM   #3
SUKXOST
SUKXOST's Avatar
IF that part is true....anyone know what the ZL1 axles are rated at?
Old 10-31-2013, 12:59 PM   #4
willc1980
Drives: 2013 Camaro SS 1LE
i dont believe this is true and out the half shafts, call the dealer and get part numbers to be sure though
willc1980 is offline   Reply With Quote
Old 10-31-2013, 01:12 PM   #5
Jason P
Jason P's Avatar
Drives: 2011 2ss
Swapping a ZL1 rear end into an SS.....Search this thread alot of info there.
2011 2ss Ram twin plate ceramic clutch, Texas speed 418 LS3 235 /243 .621 / .624 cam, ported and polished heads with dual springs,magnum push rods, Hotchkis race pack, Stainless Power long tube headers with no cats, Magna Flo competition exhaust, lpe fuel pump, magnuson supercharger with overdrive and port matched blower plate, IW 8 rib pullies, AEM meth kit, id 850 injectors, 3 bar map, halltech cai, zl1 rear diff
Jason P is offline   Reply With Quote
Old 10-31-2013, 03:06 PM   #6
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Anytime you put more than 500 to the ground all the driveline components become the week links. Just go with parts designed for the power you're making. It will not be a waste of money. The ZL1 diff has been called bullet proof. So it may be worth the effort to drop the 3.91 gears into that pumpkin.
tramtwo is offline   Reply With Quote
Old 10-31-2013, 03:16 PM   #7
Synner
Drives: cars
Get a g-force driveshaft if you want reduced weight there, the 1LE is the same as the SS.
The 1LE axles are a bit different but barely any kind of improvement over the SS. If you want a strong, worry free, axle you will need to add weight there and go aftermarket or add a ZL1 rear but thats the heaviest option.
Old 10-31-2013, 03:17 PM   #8
Synner
Drives: cars
Everything in the ZL1 rear is different.
Old 11-01-2013, 11:13 AM   #9
SUKXOST
SUKXOST's Avatar
A lot of opinions, but no confirmations. Still researching myself but can't be sure yet on the hp ratings for either axles or driveshaft for the 1LE.
Old 11-01-2013, 12:14 PM   #10
Wilsonation
Wilsonation's Avatar
Drives: 2014 ZL1 Vert
The 1LE is advertised as using ZL1 axles...
2014 1SS 1LE:
10/9/13 Ordered
10/16/13 Queued
10/28/13 TPW
11/2/13 Built and Bayed
11/7/13 Shipped
11/14/13 Brought home!
Wilsonation is offline   Reply With Quote
Old 11-01-2013, 12:36 PM   #11
Synner
Drives: cars
No its not, just upgraded axles.
Old 11-01-2013, 12:37 PM   #12
Synner
Drives: cars
You will never find a factory HP rating on driveline components because every time someone breaks one with 1hp less they'll try and sue GM.
The part numbers for the driveshaft is the SAME.
Old 11-01-2013, 12:43 PM   #13
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Come on dude... Do you honestly think your setup pushed hard through an OEM driveline will be uneventful forever?!
Nothing OEM on these cars were made for that kind of power. Your driveline upgrades are the next frontier. Now get to modding!!
Old 11-01-2013, 12:51 PM   #14
sycraft
COTW 5/06/2013
sycraft's Avatar
RH ZL1 Axle 22953759 retail 622.50
RH 1LE Axle 22806796 retail 277.90
RH SS Axle 22813728 retail 251.44
The 1LE axles are an upgrade over the SS axles, no reports of them breaking yet, but DSS and similar are great.
