Old 11-03-2013, 02:25 PM   #1
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
ZL1 diff
Tried the search didn't find an answer
The GM parts guy i am dealing with is saying that you can buy the ZL1 ring & pinion without buying the complete assembly if this is true can you do the swap or do you have to swap the complete diff assembly & is it a direct swap if it is possible .
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 11-03-2013, 10:08 PM   #2
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
what's the part number, look it up on GM parts.com or Parts Taxi.....
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 11-07-2013, 07:17 AM   #3
alssiri
alssiri's Avatar
If you check GM parts catalog this what you find :
UNIVERSALS & REAR AXLE / REAR AXLE / DIFFERENTIAL / RING & PINION
RING & PINION Camaro; 6.2L; w/Supercharger; Manual Trans
MSRP Online Price
$402.90 $238.85
View Part Diagram -- Item #13
http://www.trademotion.com/parts/201...diagram=ZB3080
it seems that something wrong there cause no one has swapped these yet
so anyone can confirm swapping the M6 3.73 diff in to an A6 ? & is it worth it or should wait for an aftermarket ring & pinion to hit the market.
Ahmad
2012 ZL1 A6 (SOLD)
Old 11-07-2013, 07:19 AM   #4
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
MSRP Online Price
$402.90 $238.85
Ahmad
I have the 3.73 in my ZL1 A6
tpower is offline   Reply With Quote
Old 11-07-2013, 07:49 AM   #5
alssiri
alssiri's Avatar
Did your order your car with this option or did you swap it ?
Ahmad
2012 ZL1 A6 (SOLD)
Old 11-07-2013, 08:03 AM   #6
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
we swapped them out the beginning of summer
Old 11-07-2013, 08:18 AM   #7
alssiri
alssiri's Avatar
So you swaped the ring & pinion ? Can you share what you did exactly & where you got the parts ?
Ahmad
2012 ZL1 A6 (SOLD)
Old 11-07-2013, 08:50 AM   #8
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
Ahmad
I ordered the new ring pinion and bearings from GM and had a local tranny shop intstall
Old 12-05-2013, 05:01 PM   #9
mylftft
mylftft's Avatar
Drives: 2013 TT ZL1
Have you taken it to the track? Any difference in et?
mylftft is offline   Reply With Quote
Old 12-05-2013, 05:30 PM   #10
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Trackman is offline   Reply With Quote
Old 12-05-2013, 06:09 PM   #11
mylftft
mylftft's Avatar
Drives: 2013 TT ZL1
Originally Posted by Trackman View Post
Oh look who just walked in!
Old 12-05-2013, 07:07 PM   #12
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
My car is getting the auto rearend swapped right now. I'm pretty certain Andy is doing the entire diff and not just the ring gears. He will have a manual set-up laying around if someone needs it.....
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 12-05-2013, 08:11 PM   #13
Trackman
Trackman's Avatar
I shifted to 5th on my fast run. I would have been faster had it stayed in 4th.
I think 3.73's would slow me down. Now if I was a turbo car maybe that makes sense to get going.
You should get Andy to bubble wrap your car.
Maybe some coon skinned seat covers?
Old 12-05-2013, 08:58 PM   #14
mylftft
mylftft's Avatar
Drives: 2013 TT ZL1
I shifted into 5th way before the finish line, my mph is just stupid!
