Old 11-06-2013, 12:54 PM   #1
JWoj3540
JWoj3540's Avatar
Drives: 2012 2SS/RS M6
Moisture from Garage Floor during Storage
Of the zillions of car storage tips, I have a question on this one...
What are some ideas to prevent moisture from corroding the underbody? Is spraying WD-40 on the underbody enough or should I get a large plastic tarp and park over it?
Thanks.
JWoj3540 is offline   Reply With Quote
Old 11-06-2013, 01:39 PM   #2
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
I have been storing in my garage for years with my old 1994 GMC Sierra (that I replaced with my Camaro). I never had an issue with corrosion from the concrete floor. Personally, I am not to concerned about it, but I have seen people park on sheets of plastic if you are worried.
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 11-06-2013, 02:19 PM   #3
436SS
436SS's Avatar
Drives: 2010 1SS
Park it on 3/4 inch plywood.
436SS is offline   Reply With Quote
Old 11-06-2013, 02:34 PM   #4
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
WD-40 should be plenty to protect your ride from corrosion not even sure you need that! I use that on my 4x4 trucks before big shows and mudding makes it easier to clean up after having to much fun.
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
Old 11-06-2013, 02:38 PM   #5
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
With over 40 years of experience in storing cars here's what I've done, I run a 20" high velocity floor fan just in front of the cars at medium speed 24/7.
I'm not in favor of using a plastic tarp, if moister build up on the tarp it will never dissipate. In one of pole barns ( it only has a dirt floor ) where some trailers I use some ply-wood sheets under them, 4'x8' sheets of luan underlayment wood be a good choice and it's fairly inexpensive also.
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 11-06-2013, 03:17 PM   #6
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
space heaters on a timer? or drop lights
Old 11-06-2013, 03:20 PM   #7
EM1/SS
Drives: 11 2SS/RS M6 vert
I've used a plastic sheet the last two years. When I move my car in March, the plastic is all wet under it.
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
EM1/SS is offline   Reply With Quote
Old 11-06-2013, 04:23 PM   #8
TOYMARO
TOYMARO's Avatar
Drives: 2011 Camaro SS/RS 2SS
I like the plywood. No plastic. I like the fan idea too.
my .02
TOYMARO is offline   Reply With Quote
Old 11-06-2013, 04:47 PM   #9
rock1962
rock1962's Avatar
Drives: 2018 Camaro SS
If you are concerned about moisture lay some large sheets of heavy cardboard to park on
rock1962 is offline   Reply With Quote
Old 11-06-2013, 05:21 PM   #10
DARK AGE 53
Drives: 2010 SS
JWoj3540, do you plan on having a DD parked next to your Camaro doing the winter months, if you do that might call something different all together.
Old 11-07-2013, 12:48 PM   #11
JWoj3540
JWoj3540's Avatar
Good point. This winter the camaro should be all alone with no daily driver near it.
Old 11-07-2013, 12:49 PM   #12
JWoj3540
JWoj3540's Avatar
Thanks all for the suggestions. Some good ideas here I hadn't before thought of !
Old 11-07-2013, 01:01 PM   #13
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
The only time moisture will be a problem is when the car is cold and you open the door to the outside and its warmer and humid outside. This will cause condensation to form on the colder surface. I have a truck I have been storing in the garage since 1987 and moisture has never been an issue. No plactic no cardboard no plywood, its the moisture in the air not from the floor.
MMC is offline   Reply With Quote
Old 11-07-2013, 02:24 PM   #14
DARK AGE 53
Drives: 2010 SS
If you have to park your DD next to the Camaro here's a couple of suggestions, http://www.carcapsule.com , http://www.carbag.com ....the Car Bag is made in Bath, Mi which is only 8 miles from me. If you'd like I can go check them out for you.
