somebody educate me
I would like to say Im a gear head, and probably know more than the average guy, but still am a novice.
When it comes to HP there is at the wheel and at the FLY. How the numbers we get are at the FLY correct? And and the wheel is always less. is this because everything behind the motor never really keep up with the Fly or what.
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
#2 | |
![]() Drives: #5 Tom Henry Racing 2010 2SS/RS Join Date: May 2009
Drives: 02 Silverado, 09 Vue, 10 1SS Join Date: Aug 2008
Location: Tired of apologizing when we should be kickin' butt!
It's due to losses in the drive line. Some of this is due to friction. Flywheel numbers are read AT the flywheel. TO correct from RWHP to flywheel HP you need to know the driveline loss.
i just posted a responce but it didnt show up haha? basically the flywheelhorsepower is figured out exactly like "it is what it is" said it is. The loss comes because off stuff like friction and pressure when the power is being transfered from the fly to the wheels
I know HP in all senses is kind of like theory, its true a lot of times but not always and can not always be relevant. So to get a true number can you average the two? my question is then why is HP advertised from the wheels, because that is what you are getting.
#6 |
im assuming your asking why is horsepower NOT advertised from the wheels and that would be because at the fly there is more horse power= bigger number = more attraction
just like girls are attracted to guys with bigger...erm...well we wont go there ![]() |
#7 |
yeah i understand that, but truth in advertising. But you might see that now with this govt
#8 |
well techincally it is the truth, it is making 400+ HP (SS for example) is it putting all of it to the ground? no. But it is making that much.
#9 |
#10 |
#11 |
![]() Drives: 2010 Camaro 2SS Join Date: Apr 2009
I would think the flywheel hp rating is more reliable and accurate. The problem with dynoing at the wheels brings to many variables into play. There's variation in how different dynos read the power being transferred to the wheels. With an engine dyno I thought it was more of what you see is what you get. I could be wrong I guess.
#12 |
Yep, dynos are actually fairly misleading...they can help in gauging the effects of something like a tune or an upgrade, or maybe comparing two cars at the same time, but as an indicator of performance they are not a very steady benchmark.
There's actually a good bit of truth in advertising the engine output...these engines are SAE certified which means that you should be receiving an engine with +-1% of the advertised rating...whereas your "wheel" hp rating varies based on weather, car, dyno, even the shop that performs the test.
A House Divided...
#13 |
![]() ![]() Drives: Silver SS/RS, Man 6 Join Date: Apr 2009
The drivetrain loss is different for various vehicles. For example, my automatic Trailblazer SS has a heavy duty tranny, very heavy driveshaft, heavy duty rearend, and the wheels and tires are large and very heavy as well. All this takes more flywheel HP to rotate on the dyno as compared to a strong but light weight drivetrain on a Vette. However, the flywheel HP is the same as the Vette's. My 2 cents.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers, GM 3.91 Rear Gears |
#14 |
HOOK'EM
Drives: 97 c1500/92 olds Join Date: Oct 2008
just one more thing that takes away hp to the wheels is vibration throughout the drivetrain
If you're gonna lie, at least educate yourself. | PQ | 5th Gen Camaro SS LS LT General Discussions | 185 | 07-06-2009 10:53 AM |
Educate us | Lovestanda | 5th Gen Camaro SS LS LT General Discussions | 9 | 05-10-2009 01:17 PM |
2010 Camaro SS -- NEW closeup photos of front-end!!! -- 7/11/08 | Tran | Camaro Photos | Spyshots | Video | Media Gallery | 591 | 07-17-2008 08:27 PM |
