Old 07-17-2009, 12:44 PM   #1
gtjacket
2G1FT1EW0A9118618
gtjacket's Avatar
Drives: 2010 Camaro 2SS Black/IOM M6
fuse box
Okay, i was using a plug in tire inflator and I plugged into the forward power outlet (located just below a/c and in front of stick) and I blew a fuse. I then checked the owners manual and saw that this fuse box is located under the instrument panel all the way at the end by the drivers side. I went to pull the box and noticed that it appears to be located real high under the instrument panel. Does anyone have any ideas on how to get to it. I have not tried because I don't want to screw anything up. BTW, if you are going to use a power outlet for a tire inflator use the one under the arm rest compartment.
1100, Preliminary order accepted 12/5
2000, Order accepted by GM 05/05
3000, Order accepted by production control 05/05
3400, Order broadcast 6/4
3800, Order produced 6/15
4000, Available to ship 6/16
4104, Bailment Invoice
4200, Shipped 6/19
6000, Delivered to the customer 6/25
2SS/RS BLK M6 GFX IOM interior
gtjacket is offline   Reply With Quote
Old 07-17-2009, 02:52 PM   #2
gtjacket
2G1FT1EW0A9118618
gtjacket's Avatar
So no one has replaced a fuse yet?
4200, Shipped 6/19
Old 07-29-2009, 01:24 PM   #3
Moth
Drives: 2010 Black 2LT/RS camaro
Hey man I got the 2lt and the fuse box is actually on the passanger side .. Maye that would help??
Moth is offline   Reply With Quote
Old 07-30-2009, 01:06 AM   #4
Aaron1121
Drives: 2010 CGM 2SS/RS
I just wired my radar dectector. The fuse box is super easy to get to.
-Open the drivers door.
- Look at the dash. The panel that faces the door when you open it pops right off, the fusebox is inside.
- Grab the bottom of the panel and pull. Three clips hold the cover, and the cover pops right off. The inside of the cover has a chart of all of the fuses. The two accessory ones are right in the middle.
- It's also on page 9-45 of your owners manual.
BTW-
2 Interesting things. The dash ABL connector is right above the fusebox behind the panel. It is ready to go, just not plugged in. I had my multimeter out, and verified that the connector works with the ABL dimmer switch. (Where are our vendors with aftermarket kits for the dash lighting. It should be plug and play!!)
When you open the cover to the fusebox, the Onstar fuse is there. There was some question about how to disable it. I didn't try it out, but I believe this would be the place.
Aaron1121 is offline   Reply With Quote
Old 07-30-2009, 02:23 AM   #5
Betro02
Betro02's Avatar
Drives: Powerful
I bet GM left it like that for future development, maybe the 2011 model would have a complete dash ABL or they might release it later this year. anyways its good to know that its there.
Betro02 is offline   Reply With Quote
Old 07-30-2009, 08:56 AM   #6
gtjacket
2G1FT1EW0A9118618
gtjacket's Avatar
BTW-
Thanks Aaron, problem solved.
4200, Shipped 6/19
Old 07-30-2009, 08:58 AM   #7
Baughman
Baughman's Avatar
Drives: Black 2SS/RS
I kind of hope Onstar won't be that easy for car thiefs to disable...... Kinda pointless if all they have to do is pull a panel off and pop out the fuse
Black/Black, 2SS/RS, Manual, and Polished 20's
VIN# 28396
Baughman is offline   Reply With Quote
Old 07-30-2009, 01:21 PM   #8
Aaron1121
Yeah....
I like Onstar, so I will leave mine on. But now people know where to look to disable it in case they don't pay there car payments or feel like going OJ on someone.....
Old 07-30-2009, 03:11 PM   #9
scomaro22
scomaro22's Avatar
Drives: 2010 VR 2SS! ,'09 Genesis
Speaking of fuse boxes, is anyone familiar with the newer Zo6's and how there is a fuse for the baffles in the exhaust ? I was told if you pull that fuse those baffles are wide open and the car shakes things apart ?? True or False ?? Second question is, do the new Camaros have that same fuse that can be pulled ??
scomaro22 is offline   Reply With Quote
Old 08-04-2009, 07:57 PM   #10
bluman
bluman's Avatar
Drives: '10 Corvette GS/'13 Mustang
True, but the Camaro is lacking a dual exhaust mode, meaning the baffles open up at 3000 rpm and close under 3000 rpm , thus dual mode exhaust,
I have a bypass switch installed that keeps them open at all times, sorry to say this does not work in the Camaro
2010 Camaro SIM/CGM RS/2LT VIN #310 SOLD
2010 Corvette Grand Sport
bluman is offline   Reply With Quote
Old 12-03-2010, 06:22 PM   #11
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
Didn't even know about the inside fuse box, after I found it and pulled F-13 - IT WORKED! My iphone is now being recognized and controlled by the head unit like it was before. No reseting of the clock or anything like that.
Irnwkrkev is offline   Reply With Quote
Old 12-03-2010, 11:48 PM   #12
SSFury
My Road Rage is Legendary
SSFury's Avatar
Drives: 2011 IOM 2SS/RS "Fury"
Not to bring out something that will help auto thieves, but onstar works through satellite signals. Hence.. the shark fin on the roof. All the would be car thief needs is one swing with a hammer, or large rock to break off the shark fin, and onstar is gone.
I was just told that yesterday by the technician installing lo-jack on my car. I have onstar, its all nice and all, but ill keep my lo-jack just the same.
~ Fury
SSFury is offline   Reply With Quote
Old 12-04-2010, 12:45 AM   #13
pogiskier
pogiskier's Avatar
Drives: 2011 camaro 2ss black,hurst shifter
It's actually cell phone through verison. If you are a verison customer you can add your car to your family plan, the min. are much cheaper that way.
you are right rip the fin off and by by signal.
pogiskier is offline   Reply With Quote
Old 02-25-2011, 10:21 AM   #14
badpig
badpig's Avatar
Drives: 2010 Camaro LT1-Cyber Grey
which of these fuses would have permanent power running to it not just when the key is turned?
Chrome don't get you home...
badpig is offline   Reply With Quote
GMPP Air Box upgrade kanys Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 21 05-02-2010 11:00 AM
CAI vs Air Box rforbes Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 06-25-2009 02:32 PM
No "Show Signature" Box in Miscellaneous... RPO_Z28 Site Related Announcements / Suggestions / Feedback / Questions 10 06-20-2009 12:08 AM
1972 Z28 on Papa John's Pizza Box! ScottZ28 1st & 2nd Generation Camaros 9 05-17-2009 07:16 PM
