Old 11-25-2013, 08:33 PM   #1
Ayala2SS
Drives: 2010 camaro 2ss silver ice metallic
Car shuts off when I high rev, or coming to a stop.
I installed a 2.9 whipple and have been having problem with my idle car keeps turning of after letting go of the gas. Last time I was going 120 on a fun acceleration and once I let off out of no where rpms dropped dead car shut off. Smh can't find the problem sprayed the car no boost leaks. Could it be TUNE?? I have a zl1 gas pump and BAP so idk what's wrong ggrrrhhhh anyone can help please?
Ayala2SS is offline   Reply With Quote
Old 11-25-2013, 11:37 PM   #2
lakersftbl69
lakersftbl69's Avatar
Drives: 2010 camaro ss
Most likely the tune
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 7/8" LTH w/ deleted cats, corsa exhaust, hurst short throw shifter stage 3 comp cam, 3.91 gears ecs kit blower, meth injection, upgraded axles, drive shaft, McLeod rxt clutch, fully forged 416ci stroker all installed and dyno tuned by slowhawk performance in bridgewater ma.
lakersftbl69 is offline   Reply With Quote
Old 11-25-2013, 11:44 PM   #3
Supercharged SS
Drives: 2010 Camaro
It's def in the tune. Is it the Whipple tune? Or who's the tuner?
Old 11-26-2013, 12:51 AM   #4
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
I'd check MAP sensor against tune make sure they are matched ie 2 bar or 3 bar & tune is set to coincide which ever you have, you would see this happening as i did until corrected.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 11-26-2013, 06:30 AM   #5
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
I must say it does sound very coincidental to the Whipple install, however I had something similar happen to me several months back. My car would randomly die when pulling up to a stop, but it would start right back up. This went on for a couple of months and no one could figure out what was wrong. Finally, it died at a light and I almost didnt get it started. Changed the battery (it was original to my 2010) and have had no further problems. I know that sounds weird but it worked for me.
Good luck on finding the gremlin. Sometimes those sort of things can be most aggravating.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 11-26-2013, 10:41 AM   #6
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Battery was probably fine, but pulling the battery reset all the electronics, and when getting a tune I always disconnect and reconnect the battery afterwards. Did you get that battery tested? I'd bet it was fine.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 11-26-2013, 11:05 AM   #7
Unreal
Drives: 2006 Z06
Bump base idle airflow up until it stops doing that. Bumping the idle RPM a little for the extra load should help too, but who knows where it is at now.
Either way, it is a tuning issue.
Nick
Corvette Z06 -1200ish rwhp
Old 11-26-2013, 12:33 PM   #8
BiggFoot
BiggFoot's Avatar
Battery tested bad.
Blower Cam
RPM Level VII
TR6060
Old 11-26-2013, 03:19 PM   #9
ayousef
ayousef's Avatar
Drives: 2013 ZL1
I didn't read the whole thread BUT, for starters DISABLE deceleration fuel cutoff and tell us what happens.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
car turns off, help me, idle, tune, whipple
