Old 11-29-2013, 12:31 PM   #1
sonnydurden
sonnydurden's Avatar
Drives: ‘16 1SS & ‘19 1LT
Adding Oil Since Driving in Manual Mode
I had to add oil in between oil changes since driving in manual mode on my L99. I have noticed that I drive harder in manual mode because the car feels more responsive and powerful.. Is this dangerous for my engine and maybe I should go back to driving in regular mode???
sonnydurden is offline   Reply With Quote
Old 11-29-2013, 12:46 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Do you have a catch can?
Click to view my build thread
Old 11-29-2013, 01:36 PM   #3
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Apparently you tend to "wind it out" more when using your paddles, than the computer shift points in "D" or "Sport" mode. This would naturally lead to using a little more oil w/ continuous use of the paddles. The computer won't let you blow up your engine, even in full Manual mode, and so long as you keep an eye on your oil level it probably won't do any harm.
Personally, I rarely use the paddles - "Sport" mode (with the higher shift points) will allow you to jump on it harder without having to worry about when to shift.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 11-29-2013, 01:45 PM   #4
MYDLIFECRISIS
MYDLIFECRISIS's Avatar
Check it frequently if you always drive it that way...won't do any harm always using the paddles. Enjoy it like it's meant to be!
MYDLIFECRISIS is offline   Reply With Quote
Old 11-29-2013, 01:45 PM   #5
sonnydurden
Hey Stig, I don't have a catch pain.. Do I need one??...
Thanks PalmerGA!!.. Will give it a try!!
Old 11-29-2013, 02:04 PM   #6
PalmerGA
PalmerGA's Avatar
Not to speak for Stig, because he knows a whole lot more about these cars than I do... but the Catch Can traps most of the oil (and other crap) that goes through the PCV valve on it's way back into your throttle body to be "reburned" before being exhausted. The process is a pollution thing that tends to (in time) cause the formation of a lot of gummy deposits in your intake, eventually making it much less efficient in burning of the fuel.
If you have a catch can, it captures most of that crud before it gets back into your engine thus, keeping your engine cleaner and efficient for a much longer period of time. Cleaner intake, cleaner valves, etc. This is especially effective for V6 engines but benefits V8s as well. I have one and drain off a couple of ounces of crud at each oil change (every 5K miles) that would otherwise have gone back into my engine. Without one... the harder you run your engine, the more "blow-by" will get back into you engine.
Stig - please correct me if I'm incorrect on this (I know you will). ;-)
Old 11-29-2013, 02:39 PM   #7
Wolvie70
Wolvie70's Avatar
Drives: 2016 2SS, Summit White, A8, NPP
Everyone needs a catch can with these engines. IMO
Wolvie70 is offline   Reply With Quote
Old 11-29-2013, 02:40 PM   #8
The Stig
The Stig's Avatar
You pretty much nailed it actually.
So while you don't need a catch can, I'd strongly recommend getting one.
Old 11-29-2013, 02:42 PM   #9
not
Drives: Camaro 2SS/RS
What kind of oil do you use? If you change the oil at every fill up you won't have this problem.
not is offline   Reply With Quote
Old 11-29-2013, 02:47 PM   #10
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
Change the oil at every fill up?????
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 11-29-2013, 04:15 PM   #11
PalmerGA
PalmerGA's Avatar
Great! See how well you guys have educated me?
Old 11-30-2013, 06:53 AM   #12
sonnydurden
Thanks guys this was some very helpful information..Catch can it is!!!
Old 11-30-2013, 09:59 AM   #13
not
Your initial posting that started this thread was about the need to add oil since using the paddle shifters almost exclusively.
Now you plan on adding a catch-can for the above......do you plan on collecting the oil and putting it back in? Don't understand how the catch-can is going to help with your oil consumption...
Old 11-30-2013, 10:10 AM   #14
pocketcthulhu
pocketcthulhu's Avatar
Drives: 2014 2ss/RS 5th gen Camaro #2
I'm REALLLLY hoping he means CHECK the oil at every fill up.
pocketcthulhu is offline   Reply With Quote
