Old 12-01-2013, 11:43 PM   #1
LS3or1LE
Drives: 1989 RS Camaro
Modifications for the track!
Hey guys! just wanna open this up, what would you all recommend to get a 1le track ready!? Im not talking what is REQUIRED by the class and sponsor but what you guys would recommend! Anyone know of good bolt on roll cages or should I get a 5 point harness? Also Pedders Permagrin kit seems like a cheap must have to take our 1le's to the next level!
LS3or1LE is offline   Reply With Quote
Old 12-01-2013, 11:48 PM   #2
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
Steel braided brake lines, castrol SRF fluid for starters....you can do a harness bar and 5 pt belts...and of course, buy all the Pedder's you can afford....
So Cal Camaro is offline   Reply With Quote
Old 12-02-2013, 12:04 AM   #3
LS3or1LE
Whats the advantage that comes from brake lines other than longevity? and castrol SRF is overpriced
BUT....you are right it is really nice, and of course, pedders equals winning.
Old 12-02-2013, 12:10 AM   #4
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
Not having brake fade is the advantage, you need some better brake fluid and the braided lines to help avoid it....I didn't even recommend better brake pads yet...Hawk DTC30 front/HP+rear at a minimum...I run Cobalt Friction...
spending money improving the brakes is an investment in your safety, don't skimp....and some track insurance is not a bad idea if going out on a road course with others...
Tyler at JDP Motorsports can hook you up with all you need for a good deal....buy from people who actually race...
Old 12-02-2013, 12:25 AM   #5
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
Good brake fluid is the #1 most important mod for tracking your car. Your next best bet is an agressive chassis alignment. Then look at racing belts, Pedders 1le kit, and so on... as you push your car harder the things that need improvement will start to stand out.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 12-02-2013, 12:36 AM   #6
LS3or1LE
I see in your signature it says custom oil cooling system, were you having issues? and did you just put a wider oil cooler on?
Old 12-02-2013, 01:29 AM   #7
White_SS/RS
Drives: 14 1LE
The factory oil 'cooler' wasn't cutting it, I would be getting engine oil temps around 270* while the water temp stayed at 210*, transmission at 180*.
I designed the system using improved racing's oil thermostat and an Earls oil cooler mounted in front of the radiator. I made up and ran all the lines and the brackets. Nothing is offered as a bolt in kit so I call it my custom job. Haven't had a chance to put it to the test yet.
LMS Engineering
Old 12-02-2013, 07:18 AM   #8
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
The only thing required is brake fluid. Other than that if you want to change the alignment you can (I did). Because you are coming from another Camaro this will feel like a totally different car. Take is out an see what YOU feel it needs and then go from there.
You can read some of my threads In my sig about tracking the car stock. (With a brake fluid change and alignmnet.)
Matt
Old 12-02-2013, 05:33 PM   #9
LS3or1LE
Matt
Is alignment just like the camber and stuff? And will it still be street able and wear the tires normally with an aggressive alignment?
Old 12-02-2013, 09:16 PM   #10
toehead93
Drives: 2014 2SS/1LE
A cheaper alternative to a harness bar and 5/6 point harness is Schroth 4 point rallye 3 which has antisubmarineling built into the design. Brakes are a good start, definitely to the fluid and alignment first then once you get a feel for the car around the track and defending on how often you track it look into brake upgrades. There are several routes to go from track pads to 6 piston front calipers (like the ones I am selling). Theb there are the typical bolt-ons as well for more power.
I am in my phone otherwise iwould post a link to peders recommended alignment specs.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 12-02-2013, 09:21 PM   #11
Msmall143
Msmall143's Avatar
Drives: Camaro
Helmet!
Msmall143 is offline   Reply With Quote
Old 12-02-2013, 10:05 PM   #12
LS3or1LE
Originally Posted by Msmall143 View Post
Helmet!
Thats important
Old 12-02-2013, 10:17 PM   #13
toehead93
Overrated
2010 2SS A6 - sold.
Old 12-03-2013, 12:18 AM   #14
White_SS/RS
Drives: 14 1LE
Do the brake fluid and and get a helmet. If you want to invest in more go fast stuff, the guys above have offered some great starting points.
Above all... Have fun!!
LMS Engineering
