Old 12-06-2013, 06:10 PM   #1
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
Solo High flow cats and o2 sensors
Below you can see all my aftermarket parts.
I have a P2096 CEL code. Cleared it and eventually it came back. I took it to the dealership and they said that it is because my O2 sensors are getting a false reading due to the relocation of the sensors. Is this possible? Anybody else have this issue?
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 12-06-2013, 06:52 PM   #2
KMPrenger
KMPrenger's Avatar
SOLO claims their high flow cat setup shouldn't cause a CEL, and it seems most of the time they don't, but I have heard of it happening before.
You can contact SOLO and see if they have any recommendations. I'd start there, but I'm guessing there may not be a solution other than getting a tune.
Old 12-06-2013, 07:10 PM   #3
skibik
Guest
Drives: bbbbbb
I have yet to have a code with my set up and been running it since February. Solo should be able to help you out.
Dean.
skibik is offline   Reply With Quote
Old 12-06-2013, 07:42 PM   #4
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Check for vacuum leaks, and exhaust leaks at the flange, o2 sensors, joining connections etc. Both of these can cause that code.
Generally you would see a P0420, and/or P0430 code for high flow cats or headers.
Jason@JacFab is offline   Reply With Quote
Old 12-06-2013, 08:37 PM   #5
bionick
bionick's Avatar
Well they claimed to have checked everything and are "positive" it's the o2 sensors
Old 12-06-2013, 08:45 PM   #6
bionick
bionick's Avatar
Ya I've been talking to them and they say this shouldn't be from the cats but the dealer says it is so I have no idea what to do
Old 12-06-2013, 09:37 PM   #7
bionick
bionick's Avatar
Dean.
I've got the same mods as you but different brand axle back and different CAI.. Weird. I wonder if my MAF sensor got dirty, I heard that could cause this code? Not sure. I do live in the dusty arizona though
Old 12-06-2013, 09:39 PM   #8
bionick
bionick's Avatar
Also,
I had it professionally installed since I did not have the proper equipment, and after I got the code i took it back to have them check for leaks and they said all was good. I'm so confused.. Haha
Old 12-06-2013, 09:48 PM   #9
BLU DUCE
BLU DUCE's Avatar
Extensions
Originally Posted by bionick View Post
Also,
I had the same problem last year & dealer was a pain in the a$$. Call solo and have them send you two o2 sensor extensions. I kept through the same code. Put the extensions in cleared the code & it never came on again in the last year & half. Its up 2 you try it. The only code I was throwing was the P0430 & I also have Doug Thorley ceramic shorty headers.
Old 12-06-2013, 10:18 PM   #10
bionick
bionick's Avatar
Thanks for the response. I have the rear bung extenders installed already
Old 12-06-2013, 11:31 PM   #11
bionick
bionick's Avatar
I'm just confused because from what I've researched, rich conditions results in lack of power and decreased gas milage. On the freeway I'm averaging 29+ MPG. Sometimes even mid 30's, and I haven't noticed a reduction in power. It also says online that changing your o2 sensor will not fix it. P2097 is bank 1 (driver side) so I wonder if I changed my driver and passenger o2 sensors if I would get P2099 bank 2..
Old 12-07-2013, 06:55 PM   #12
skibik
Guest
Drives: bbbbbb
If you switch O2 sensors and get a code on the other bank it may be an indication of a bad O2 sensor. If you get the code for the same bank then it is different problem. If I remember trying to install mine you have to get the O2 sensor back in the positions that they came out of the stock pipes and if memory serves correctly I thought the connectors for front to rear O2 are different but they maybe are the same for side to side. As far as the MAF not sure that would set off a code for the O2 sensors but maybe it could be messing with the fuel mixture. I have never cleaned an MAF in my life so I really could help you. I know they make a special spray cleaner for them and maybe would not hurt to give them a cleaning. Not sure if a battery disconnect would help you out either. You could try leaving it disconnected overnight and see if that help clear it.
Dean.
Old 12-07-2013, 10:01 PM   #13
bionick
bionick's Avatar
Dean.
Thanks for the info.
The dealer said my car is running fine and the air/fuel ratio is good,
So there's gotta be something going on that's tricking my car to think that it's off..
I want to swap the o2 sensors on both sides but I don't have anything to lift my car, and with Christmas and all that coming up I really don't wanna spend the money on a jack and stands right now just to swap out sensors which may not even do anything for me. I'll do that as a last resort. A shop near my house said that intake systems can cause this code so I figured i should spend a few bucks on the cleaner and give it a shot..
Is there a difference from hooking up to your OBDII and clearing the code opposed to a overnight battery disconnect?
Old 12-08-2013, 12:18 PM   #14
skibik
Guest
Drives: bbbbbb
Someone else will have to answer that. Just wondering if you did a battery disconnect when you installed the CAI? Since the shop near your house mentioned it could be the intake system a battery disconnect may help clear the code. Just pop the negative terminal off and leave it overnight if you can. I know some have had trouble with codes, unsure which ones, after a CAI install. In my instructions for the Injen CAI step one was to disconnect battery, but didn't give a reason. Out of the CAI, the ported TB, and the HFC's I haven't had a code. Not sure if the shop that I had install the HFC's did a battery disconnect though. He also wasn't sure why they needed an extension on the O2's but I made sure to tell him that it was needed. Hopefully you get it figured out. I wished I could be of more help.
Dean.
cel, p2097, solo high flow cats
