Old 12-13-2013, 06:46 PM   #1
niterat
niterat's Avatar
Drives: ZLI IOM Convertible
belly pan on a vert?
Has anyone here tried to mount a belly pan on a convertible? This is one of my winter projects and I thought I'd start by seeing if someone has already done it.
niterat is offline   Reply With Quote
Old 12-14-2013, 07:26 PM   #2
RolltideSS
RolltideSS's Avatar
Drives: 2018 SS 1LE
Are you referring to a panel that would go under the engine/front end to cut drag? If so then I think all the ZL1 camaro verts have one
RolltideSS is offline   Reply With Quote
Old 12-14-2013, 08:47 PM   #3
hawk02
Coupe Newbie
hawk02's Avatar
Drives: '23 CT5-V BW, '21 Corvette HTC
No belly pan on the ZL1 vert. The added cross bracing interferes with the fit so it was left off.
hawk02 is offline   Reply With Quote
Old 12-14-2013, 11:48 PM   #4
RolltideSS
RolltideSS's Avatar
Drives: 2018 SS 1LE
Interesting, I assumed all zl1s had it. Would think GM could design one with holes cut for the cross bracing to run through.
Old 12-15-2013, 10:22 AM   #5
hawk02
Coupe Newbie
hawk02's Avatar
My guess is that GM felt the cost and effort to develop a second belly pan just for the convertible didn't make sense given the smaller market for convertibles. Add in the fact that many tracks won't allow verts to race without some form of approved roll protection and I can kind of see their point.
Old 12-15-2013, 07:09 PM   #6
AMMUSCLE
AMMUSCLE's Avatar
Drives: 2013 ZL1 VERT M6
Let us know if you try it.
I do not know if this can be done.
JANNETTY RACING 750 ROUGH IDLE CAM PACKAGE
(681 RWHP & 643 RWTQ) = 783 CRANK HP & 740 CRANK TQ
AMMUSCLE is offline   Reply With Quote
Old 12-15-2013, 08:05 PM   #7
Allanski
Drives: Car
We put on an aluminum pan to keep the air from getting under the rear bumper cover while going down the drag strip.
Also look at the last pic, and focus on the black subframe connection bars.
Along with the roll bar the car is quite rigid.
Allanski is offline   Reply With Quote
Old 12-24-2013, 04:56 AM   #8
niterat
niterat's Avatar
Hawk02 is absolutely right. My ZL1 vert doesn't have the pan So I am putting one in. The best option would be to be able to reform it around the braces but I lack the tools for that. I will probably just mount it under the bracing with spacers and a gasket. The front will take some cutting though as it needs to go up over the back of the splitter. The bracing is in the way of that which is why I think I'll have to cut.
Old 12-24-2013, 05:09 AM   #9
niterat
niterat's Avatar
I like that aluminum pan!
Old 12-29-2013, 11:37 AM   #10
sswiss3000
sswiss3000's Avatar
Drives: 2012 Camaro 2SS Vert, L99
Belly Pan on Vert Installed
Hi all,
I just finished my complete ZL1 Front end conversion, including Brake Ducts, Wheel liners and Belly pan. As it is pretty damn cold out right now I just mounted the Belly pan over the convertible bracing. Once it gets a bit warmer out I will use a Heat gun to warm the plastic and have it conform to the bracing a bit more, but in general it fits perfectly over the bracing already. Here are a few pics I snapped, you can see how the belly pan simply bows a bit over the Bracing.
FYI, all 2012 and up Camaros have the mounting holes for the Nutserts into which the Belly pan is screwed.
sswiss3000 is offline   Reply With Quote
Old 01-03-2014, 06:15 PM   #11
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Rear Pan
Attachment 583105
Attachment 583106
Attachment 583107
What is the plastic behind the diff an in front of the rear pan??
