Old 12-21-2013, 01:26 PM   #1
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
CCFL lighting issue
I have CCFL foglights and they are building a caramel like crust inside on both of them. So then one of them starts not working. Question.
Is that normal ??? and if so what can I do to fix them ??
I've had these foglights installed less than a week. There has been no water near it. (my car is filthy) so what can it be that is causing this ??
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 12-21-2013, 02:00 PM   #2
Brandonmos
Brandonmos's Avatar
Drives: 2013 1SS 1LE
something was shorting out/ overheating and melted the housing
Killed so many water bottles that day...
Brandonmos is offline   Reply With Quote
Old 12-21-2013, 02:02 PM   #3
rgrmoreira13
The inside of housing was 8K HID bulb that was included in the kit.
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 12-21-2013, 04:58 PM   #4
05stram
Drives: 2013 RS - 2013 2SS/RS - 1971 RS
imho 8K is too much heat without venting the housing. how many watts is the 8K bulb I believe most people are running the 4300K at 6 watts to match it up close to the HID some maybe running the 11 watt bulbs
05stram is offline   Reply With Quote
Old 12-23-2013, 12:04 PM   #5
rgrmoreira13
Those 8K HID bulbs were gotten from the same distributor. I did not get them elsewhere. So I don't know what else it could be. and if the bulb did it then why wasn't it burned evenly ? It was only burned on top. Not all over.
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
