Old 07-21-2009, 02:44 PM   #1
jordan 572
jordan 572's Avatar
Drives: none
x pipe question
what does an x pipe do or gain you
jordan 572 is offline   Reply With Quote
Old 07-21-2009, 02:53 PM   #2
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Hotrod Magazine's breakdown of Exhaust 'science'
Similar discussion utilizing an upgrade on a 1971 Lemans
What I gathered skimming during class:
"Functionally, the difference between the X and the H is, the X type forces the exhaust to cross between both sides. Based on the performance increases we noted with the X crossover, the scavenging forces created by the gasses crossing over in this way appear to be stronger and more effective across a wider range of engine speeds.
Whereas conventional dual exhaust systems have a characteristic rap or low rumble when the engine is under load, the X type crossover has a higher pitched smoother note."
So you're probably going to make the engine breathe better by mixing the exhaust outputs and allowing both sided of the V to use the whole system rather than one pipe per side. Also helps increase power and decrease pressure buildup in the exhaust due to all the bends made.
Zabo is offline   Reply With Quote
H pipes are a must Pyottboy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 05-16-2010 09:55 AM
Please answer my question... IROCanSS 5th Gen Camaro SS LS LT General Discussions 23 07-16-2009 06:49 PM
Question about the After.... Tecca Camaro Price | Ordering | Tracking | Dealers Discussions 1 04-15-2009 05:05 PM
question on install: GMPP cat back exhaust detroitboy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-04-2009 01:52 PM
OK WILL SOMEONE PLEASE ANSWER THIS QUESTION OM FINANCING leatherneck Camaro Price | Ordering | Tracking | Dealers Discussions 22 03-26-2009 04:53 PM
