![]() ![]() ![]() ![]() ![]() ![]() Drives: Black 2011 2SS/RS Join Date: May 2011
Harness bar install
I didn't see an install for a harness bar so I made one today as I did my install. Please feel free to comment or ask questions.
Four point harness install added Last edited by mp51998; 01-10-2014 at 05:24 PM. |
Do you have pictures of the belts installed. Do they connect directly to the bar or do they fasten to an anchor point?
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
#3 | |
I did get the two inch four point harness so I'm not sure if the 3 inch five point is the same. |
#4 | |
![]() Drives: 2011 CGM 2SS/RS Join Date: Apr 2011
![]() Hopefully you all figure out the best way to do the belts before I start my install. |
I'm gonna look at it again tomorrow. Which belts did you get?
#6 |
#7 |
#8 |
This is great. I am going to do this and knowing the best way to mount the belts will be helpful. My concern is making sure they cannot pull lose from the anchor point.
#9 |
Do you even lift, bro?
So....think my top bar had a stripped/burred hole and I could NOT get a bolt in....stripped the bolt trying to get it in....had to go to the hardware store to get an identical bolt....think I got it....now I have to use a tap and die set to re-thread the bar hole and try to get this new bolt through. UGH!
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461 |
#10 |
Just take it slow and easy with the tap. Go in a little then back out. Will take several times but best to be sure. Good luck
#11 |
I got the harness mounting figured out. No need to cut the tabs off. I do need to get two bolts that I can not get until tomorrow. I will have a DIY tomorrow by mid day
#12 |
#13 | ||
-allow the seat belt to retract better on it's own -to extend the angled bars further and hop to tighten up the whole set up to not have that slight "slack" Quote:
#14 |
Reaper Crew
Drives: Blown 2010 Camaro SS Join Date: Aug 2012
Wish the tank plates weren't so expensive. For some reason, the Camaro tank plates are the most expensive.....about $200 more than the corvette tank plates
2010 Camaro SS SLP TVS2300 Blower, Blower Cam, Lingenfelter Heads, Meth Injected, 5lbs of Boost@700 BHP Pedders XA Coilovers |
