Fan noise
Hey guys I did a search but found nada in this issue, 2014 SS with 8K on the OD, when the fan for heat/ac goes on low to med it makes almost like. Whistling cricket noise, once I turn the dial up it goes away till yet again when I start sweating and have to lower it. Anyone else have this issue? It seems ever so slight I don't know if it will be able to be fixed. Any out is welcome.
Have had my car since 1 mile and this never happened before until today |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
Sincere apologies about the fan noise. I understand any frustration this causes. While I notice that you're seeking thoughts and opinions, you're welcome to send us a message for assistance with setting up an appointment for an official GM diagnosis. At that point, I'll reach out to the dealer's customer care specialist who is the point of contact for resolving customer/vehicle issues at the dealer level. William R. Chevrolet Customer Care |
![]() Drives: 17 Fifty SS, 11 2SS, 91 LSX C1500 Join Date: Apr 2013
I have the exact same problem
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
Im having the exact same issues with my 2012 and in the "problems" section on here, there's been tons of other 2010+ cars with this issue.
Mines going in on the 13th to get looked at.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
![]() Drives: 2012 1LT Drop Top Join Date: Oct 2013
I have this problem also. 1, 2 and 3 fan speed it's there, then just about goes away on 4 and gone at 5 and above. Dealer said no problem found. Pulled out after picking it up and brought it right back for him to listen. The tech came out and heard it so I'll have him fix it the next time. It isn't very loud but it is annoying.
#6 |
![]() Drives: 2011 LT Black Join Date: Nov 2011
Mine wouldn't make the noise for the dealer....of course.
#7 |
![]() Drives: 2011 Camaro 2SS/RS Vert Join Date: Jul 2011
I have the same issue....it drives me insane!!!
#8 |
I have had the same issue on my '11 but only in the early morning and not every day. When it does happen it is fairly loud. A definite squeak.
#9 |
Love me some Tacos
My friend had his fixed, they have to cut the motor out of the box and replace. Great part is the sound came back (I believe). Mine has same issue I just don't care about it as much. I think there is a TSB out on this from the earlier models.
#10 |
I have this problem every morning now. I have only heard it in the cold weather too.
#11 |
![]() Drives: 2018 1SS 1LE M6 Join Date: Jul 2013
it seems like evey camaro has this problem, i have it to it drives me insane sometimes. i brought it to the dealer and its getting fixed tuesday
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Common problem.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
#13 |
Thanks guys doesn't make me feel any better that it's a common issue and you all r experiencing it as well, you would think an easy fix they would have gotten it str by now I'll follow up after I bring it to the dealer
#14 |
Boosted
Drives: 2012 1LT RS... with snails Join Date: May 2012
I had this problem last year. I had a thread in the warranty section. I fought with my dealer to replace it. They said I was hearing things. finally they replaced it under warranty. I noticed yesterday that it's doing it again. It's the fan bearing that squeaks. I think the bearing can't handle cold weather.
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani* |
