Old 01-15-2014, 04:47 PM   #1
Beaver Creek
Beaver Creek's Avatar
Drives: 2011 Camaro Synergy II
Any problems with side to side Pirelli rotation?
I have 25,000 miles on my Pirelli tires, and the right rear is wearing more than the left. Should I go ahead and rotate them side to side? The tires are not directional, are they? Will rolling the opposite way cause any tire problems down the road, so to speak?
And if I do, how big of a pain is it to have the TPMS relearn the positions? I have read the manual, but that doesn't tell me if it always works the first time, or how big of a pain it is to relearn.
I am a little befuddled as to how the right rear is wearing quicker. My car has the limited slip. I have lit the tires up only a couple of times, and both rear tires were spinning. I wouldn't have thought there would be much of a difference in rear tire wear. Maybe I should have rotated them earlier.
I have the RS Package, so side to side is my only option.
Lee
Beaver Creek is offline   Reply With Quote
Old 01-15-2014, 04:52 PM   #2
Squillo
Drives: 2013 Camaro 2SS/RS BRM LS3
Owner's Manual:
http://www.chevrolet.com/content/dam...k13camaro1.pdf
Squillo is offline   Reply With Quote
Old 01-15-2014, 05:02 PM   #3
OK2DRUL
ace5.org (Atlanta Club)
OK2DRUL's Avatar
Drives: 2010 Black/IOM 2SS LS3
The tires aren't directional, so you can swap them from side to side. Pay attention to the tires when swapping as one side says inside and the other says outside. If your tires are wearing out of proportion then I would get your alignment checked. Usually swapping tires side to side wouldn't make any difference in wear unless your alignment is off.
To make the TPMS relearn is pretty simple. Just hit the menu button and go to where it shows your tire pressure and reset.
OK2DRUL is offline   Reply With Quote
Old 01-15-2014, 05:12 PM   #4
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
The P-Zeros are NOT directional tires. If they were there would be an arrow on the sidewall indicating the direction of forward rotation required. The P-Zeros only have "Outside" on the sidewalls, meaning they can be rotated side to side (but NOT front to back since the fronts and rears are different sizes).
The manual (for my 2013 anyway) recommends rotating every 8K miles, so you should be on your 4th rotation about now. I would be concerned about the uneven wear and doubt you can do anything now to rectify that by simply rotating - you may have some sort of problem that a good tire shop should look at.
Not sure about your car, but my TPMS requires a "relearn tool". Being the thrifty person that I am, I just left them alone. They work fine - I just have to remember when a left side tire reads low, it's really the right side tire that needs air. No problems so far.
I rotate my tires when I change the oil/filter... every 5K miles.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 01-15-2014, 05:14 PM   #5
Beaver Creek
Originally Posted by Squillo View Post
Duh...and thanks for reading!
Lee
Old 01-15-2014, 05:22 PM   #6
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
I'm no expert, but TPMS relearn is a little more complicated. You have to let the air out of each tire and refill. I hit that reset button once...... At the dealer for a few hours letting them straighten it out...
Eddiefuzz is offline   Reply With Quote
Old 01-15-2014, 05:22 PM   #7
Beaver Creek
OK, and Palmer,
Thanks for the replies.
I am looking for real world answers, so I appreciate it. I know I SHOULD have rotated the tires earlier, but up until lately, the tires all seemed to be wearing about the same, so I didn't see how a rotation could have been much help.
I am going to get a four wheel alignment soon, so that may tell me if there is a problem or not for that right rear.
Lee
Old 01-15-2014, 05:26 PM   #8
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
Originally Posted by PalmerGA View Post
...Not sure about your car, but my TPMS requires a "relearn tool"....
From what I understand, the relearn tool makes it quick and easy, but any of our fifth gens can also relearn the TPMS manually (though a relearn sequence on the DIC, and a few minutes worth of air out/ air in procedures). If anybody knows otherwise, don't hesitate to holler, but I'm pretty sure it can be done without the tool on all of 'em.
Scalded Dog is offline   Reply With Quote
Old 01-15-2014, 05:44 PM   #9
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Why wouldn't one rear tire wear more than the other? Your limited slip isn't engaged all the time and your not spooled. So that would mean one tire is putting the power down until it slips. Then the limited slip engages and both tires put the power to the pavement. Unless a tire is wearing unevenly across the tread of one tire, no need for an alignment, imo.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 01-15-2014, 05:51 PM   #10
Shift_Rejected
2010 2SS RS
Shift_Rejected's Avatar
Drives: 2010 2SS RS (L99)
If had to do the relearn a few times, not too complicated.
1.) press reset
2.) start with the specified tire and let out a little air (look in manual)
3.) horn honks meaning to move to the next tire
4.) repeat for all 4 tires
< 30 mins
Shift_Rejected is offline   Reply With Quote
Old 01-15-2014, 05:55 PM   #11
Beaver Creek
I thought about that.
I reckon the right rear IS still doing most of the pulling, except for when it's spinning with the left one.
Just seemed weird that it has seemed to wear more lately...
Lee
Old 01-15-2014, 05:57 PM   #12
Beaver Creek
1.) press reset
< 30 mins
Yeah...I have nitrogen though.
Probably be cheaper to go to the dealer, unless the relearn tool is not that expensive.
Lee
Old 01-15-2014, 05:58 PM   #13
suzook
Drives: camaro
1.) press reset
< 30 mins
I don't think this works on 2013 models.
2016 2SS,A8,NAV,NPP,MAG Ride,Sunroof
Hyperblue/JetBlack
suzook is offline   Reply With Quote
Old 01-15-2014, 06:14 PM   #14
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Lee
Tread depth is diminishing, so probably easier to see and to see the wear bars. Every rear wheel drive car i've ever had, has worn the right rear more. Except this one, both rears were done at 10k miles.
I believe 2013's need the tpms reset with a tool, unlike the 2010. Iirc, I read a thread where someone took their car to a national tire store and they reset it for free.
