WILDRACER
catch can install help needed
as the title says i need help with the catch can install.
what i need is to know how you take the factory hose off of the engines pcv system and the same small hose off of the factory in take manifold. how do you take these connections off with out braking them off? ![]() |
If you do a forum search there are a few write ups with pics. I installed an rx can on mine and if the installation is similar then the fittings are not removed but you cut the actual OEM line and then plumb your system into the existing line. I left around 6 inches of OEM hose on each fitting and then plugged the two hoses from my catch can into the sections left on the two fittings
Mold Your Dreams into Reality
![]() ![]() ![]() ![]() ![]() Drives: 2014 Blue Ray Met. Camaro 1SS Vert Join Date: Feb 2012
The V8 and V6 setup is different when it comes to installing a catch can!! Like he said do a forum search for the V8.
WILDRACER
my problem isnt the install ... thats pretty cut and dry there. my problem is that i dont know how to get the factory lines to disconnect.
![]() Drives: 2013 LS Join Date: May 2013
I don't think you can remove the factory line. I know you can do a quarter turn on one and it pops out, but I still had to cut both ends. Good luck.
#6 | |
![]() Drives: 2014 Camaro 1SS 1LE Join Date: Aug 2013
To answer the Ops question though of how you take those fittings off... well, there is little tab on them that you have to pull back and then they just slide right off. The tab is hard to see and almost impossible to reach without disconnecting and moving away all the hoses in the way, or I have heard some people take off the throttle body to make reaching the tabs a little easier. |
#7 |
![]() Drives: 2011 2ss Join Date: Oct 2012
2011 2ss Ram twin plate ceramic clutch, Texas speed 418 LS3 235 /243 .621 / .624 cam, ported and polished heads with dual springs,magnum push rods, Hotchkis race pack, Stainless Power long tube headers with no cats, Magna Flo competition exhaust, lpe fuel pump, magnuson supercharger with overdrive and port matched blower plate, IW 8 rib pullies, AEM meth kit, id 850 injectors, 3 bar map, halltech cai, zl1 rear diff
#8 |
WILDRACER
jason thank you for the reply but thats not the one... the one i am talking about is the U shaped hose going off of the pcv to the in take manifold i dont know how to take them off with out braking them
#9 |
![]() Drives: 2013 2SS RS Hurst NPP Join Date: May 2012
Check out my video that I made where I address this U shaped connection and how to take it off. I think I explain it pretty good in the video, but let me know if it is not clear.
http://www.camaro5.com/forums/showthread.php?t=252256 Don't you just love this forum???
No Worries
CAI Intake w/washer relocation and race scoop Ported Throttle Body (Polished) Kooks LT stepped headers 1-3/4 to 1-7/8 High Flow Cats Livernois Motorsports Stage 2c Cam Package https://www.youtube.com/watch?v=AKXyCyBh9BU Hill Start Assist Delete |
#10 |
WILDRACER
Ehmsea....PERFECT.... just what i was looking for my friend.. thank you for the reply and thank you for your work on the video work well done.. and like you said as well this site rocks and great people here as well.. thank you again for your help.
