Old 02-07-2014, 10:59 AM   #1
11 camaro
Drives: camaro rs
tpms sensors help!!!!
hello, im having alot of issues with my 2011 camaro the tpms light keeps going on ive tried to reset it and after a little drive it comes back on any help would be great.
11 camaro is offline   Reply With Quote
Old 02-07-2014, 11:25 AM   #2
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
Does it read low when you look at the tire pressure or is it blank?
My dad had one sensor that was reading nothing when we took his 45th Anniversary down to Savannah Georgia. He took it to the dealer down there and they reset it. However when I switched him out to winter tires by letting the air out, and going back to summer tires he hasn't had the problem since.
Do you have another wheel, tire you could do that on?
I did notice that the tpms sensors do run off of CR2032 batteries, so I suppose they could be going bad, or just acting up because of the cold temperatures.
skuttduck is offline   Reply With Quote
Old 02-07-2014, 04:46 PM   #3
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
You can't just press the reset button ,like resetting the trip mileage or average speed.... There is a step by step process that includes either putting air in or letting air out. Go to the DYI section and search "reset TPMS". Or take it to the dealer they should do it for free. PS I pressed the button too, when I first got my car...
Eddiefuzz is offline   Reply With Quote
Old 02-07-2014, 05:38 PM   #4
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
The letting out air method doesn't work for 2012 (or is it 2013) and later cars. Check your user's manual.
Rock-It Man is offline   Reply With Quote
Old 02-07-2014, 06:06 PM   #5
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
His name is "11 Camaro", I think he has an eleven. You quoted me to make it seem I was wrong, and YOU WEREN'T EVEN SURE OF A CORRECT ANSWER TO HIS PROBLEM!!! Go F Yourself! 752 Post, have you ever given any answer, other than check the owners manual?
I stated that I had done the same thing, and there are steps to take, check DYI, or have a dealer do it.
Old 02-08-2014, 09:16 AM   #6
11 camaro
Drives: camaro rs
thanks eddie i went through the steps like the owners manual says and now it reads nothing but i drove it this morning it seems like there trying to work but it is also cold in maryland so i dont know what to do. been to the dealership four times they even replaced the right rear sensor, these things are a pain in the ass!!!!!
Old 02-08-2014, 07:02 PM   #7
skuttduck
skuttduck's Avatar
Even though it isn't supposed to, I did it on my dad's 45th anniversary camaro for the past few years.
The menu item saying press set/clear is missing, but if you hold it, it will ask you if you want to do this, and you can do the manual method. I let out about 10 seconds of air on each tire.
Keep the other set of wheels with sensors away from the car.
Old 02-09-2014, 09:26 AM   #8
11 camaro
Drives: camaro rs
update, i got the light to go out, but as i was driving it , it seems to loose signal and the light comes back on what could be the problem with this? when one goes out the rest shortly goes out, i have all the rite tire pressure in them, HELP!!!!!
Old 02-09-2014, 09:59 AM   #9
11 camaro
Drives: camaro rs
WHERE DOES THE TMPS GET ITS READING FROM?
Old 02-10-2014, 09:28 AM   #10
Rizzo
Drives: 2012 Camaro ZL-1 SIM
Do you have a Scosche kit installed in it?
http://www.camaro5.com/forums/showthread.php?t=246752
Rizzo is offline   Reply With Quote
Old 02-10-2014, 11:15 PM   #11
Chevrolet Customer Svc
Drives: GM Vehicles
Very sorry to hear about this. I understand that you're seeking thoughts and opinions, but send me a message if you want to take it a step further and get an official diagnosis. I will then reach out to the dealer's Customer Care Specialist for additional assistance with potentially resolving this at the dealer level.
William R.
Chevrolet Customer Care
Old 02-11-2014, 05:47 AM   #12
CookieCk
Drives: 2012 Camaro SS
It does still work, it just doesn't state it in the user manual anymore. Says it requires a tool, but it works perfectly fine without it.
CookieCk is offline   Reply With Quote
Old 02-12-2014, 11:09 AM   #13
wutshotDJroomba
wutshotDJroomba's Avatar
Drives: 2012 Camaro LS/SC
I recently slapped a set of 2010 chrome SS rims with tires onto my 2012 LS I tried letting the air out to reset them and I couldn't get any reading, and the horn simply would not sound, I would start the procedure and hear the horn honk, but once I started letting air out of the first tire....no horn.... so now I'm curious do I need to take it to the "stealership" to have it reset with said tool or no? Frankly I'm at a loss for ideas other than that one, anyone got a clue lol?
"....Empty your mind, be formless. Shapeless, like water. If you put water into a cup, it becomes the cup. You put water into a bottle and it becomes the bottle. You put it in a teapot, it becomes the teapot. Now, water can flow or it can crash. Be water, my friend.”
-Bruce Lee
wutshotDJroomba is offline   Reply With Quote
Old 02-12-2014, 01:51 PM   #14
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
I have a 2011 2SSRS that I got this past August that was doing the same of my sensor going off, showing an issue with my DS/R. I got almost home and the indicator came on. I went back the next day for the reset and made it half way home again and sensor came on. Instead of driving back to my home dealership which is like 35 miles away, I went to the dealership about 8 miles away and they reset my sensor but told me I may need new sensors if it goes off again. I haven't had another problem since.
Never grow up, it's a trap!
chozn4service is offline   Reply With Quote
