Old 02-09-2014, 03:31 AM   #1
hall92
AlyssaSTORM
hall92's Avatar
Drives: Camaro SS 1LE
2013 to 2014 bumper conversion
OK I know I can't be the only one wanting to see this, but who has actually completed the 2014 front fascia swap on a 2010-2013 camaro. Post pictures please I'm curious.
hall92 is offline   Reply With Quote
Old 02-09-2014, 07:45 AM   #2
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
You go first....
hahaha.
Seriously. I think because it's pretty much going to be the ENTIRE front end, (and the hood lines not matching if you use an SS front end so it may need reworking unless you buy the hood too) it's not going to be as cheap as one might think. Especially if you have the RS package.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 02-09-2014, 10:10 AM   #3
hall92
AlyssaSTORM
hall92's Avatar
Originally Posted by el ess A View Post
You go first....
hahaha.
I want to do it but I don't even know where to begin haha.
Old 02-09-2014, 10:14 AM   #4
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
You go first....
hahaha.
Maybe with an aftermarket '14 bumper the differences in the lines won't be that great?? Just a thought
Jenner is offline   Reply With Quote
Old 02-09-2014, 12:31 PM   #5
Rideskinz
Rideskinz's Avatar
Drives: SS, ZL1, V6
Actually, we just did a test fit on a '14 a few weeks ago and the lines around the hood and fenders are exactly the same as the '10-'13. All mounting points are the same. The only difference is of course the upper grille area. Also the top surface where the mail slot is located on SS bumpers is wider from front to back. So I don't think you should have a problem mounting a '14 bumper on a '10-13 Camaro
Rideskinz is offline   Reply With Quote
Old 02-09-2014, 12:45 PM   #6
el ess A
Older Than Dirt
el ess A's Avatar
They will physically fit and bolt up. But the 2014 SS hood lines on the fascia are much wider than the 2014 V6 version. The V6 2014 fascia looks to be the same width as the 2010-2013 hood lines (non-ZL1). If I were to bet, the 2014 V6 hood is the same part number as the earlier non-ZL1 hoods. Of course, you could move the SS fascia lines to match your current hood if you choose.
Old 02-09-2014, 12:55 PM   #7
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
V6 and V8 14 dont have the same hood or bumper body lines, and then there is all the harness's needed to do it, LOL
Old 02-09-2014, 01:13 PM   #8
Rideskinz
Rideskinz's Avatar
Drives: SS, ZL1, V6
Yeah, I agree. The hood lines will be different between 2014 SS and 2010-2013. The Aggressor uses the same mounting points and upper surfaces as the 2010-2013 and as you can see, it lines up pretty well with the exception of the headlights. By the way, not trying to sell Aggressor bumpers here, lol.
Here is the Aggressor fascia installed on a 2014 V6:
Old 02-09-2014, 05:56 PM   #9
MattyDaddy
MattyDaddy's Avatar
Drives: 2012 Red SS/RS
I was JUST wondering about this myself yesterday.. I really love the way the new front end looks.. Too bad there isn't an aftermarket style option that gets close.. or is there?
2011 V6 LS.. Traded in..
2012 Red SS/RS! Woot!
MattyDaddy is offline   Reply With Quote
Old 02-09-2014, 06:22 PM   #10
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
Mine will be done next week...
L99 With a Maggie
Nutro is offline   Reply With Quote
Old 03-29-2014, 05:20 PM   #11
Mike Peters
American
Drives: 1970 Camaro
So if I randomly bought a 13 Black SS, I can get away with the 14 RS front and rear bumpers and tails, everything bolts on?
I really hate the not-quite-the-right-size hood scoop on the 14's.
70 Camaro | 383 LS1 | Magnuson Supercharger
Facebook.com/mikespeeddrift
Mike Peters is offline   Reply With Quote
Old 03-29-2014, 08:51 PM   #12
BluePhoenix
BluePhoenix's Avatar
Drives: 23 Camaro 2SS 1LE
Nutro is probably the man to ask. He just completed his front bumper swap.
2023 Camaro 2SS 1LE, A10, Summit White,
1100 - 3/23/2023
2000 - 3/27/2023
3000 - 3/28/2023
3000 - 4/04/2023 — 4/24 TPW
3400 - 4/12/2023 — 4/24 TPW
3800 - 4/28/2023 - Delayed ETA
VIN: 1G1FH1R73P0145237
5/10/2023 - ETA 5/27/2023
5000 - 5/30/2023
6000 - 6/3/2023
2024 GMC Sierra 1500
BluePhoenix is offline   Reply With Quote
Old 04-10-2014, 04:07 PM   #13
seanjhon
seanjhon's Avatar
Drives: 2013 camaro
will a 2013 zl1 front fascia fit on a 2014 ls and SS
seanjhon is offline   Reply With Quote
Old 04-10-2014, 05:14 PM   #14
el ess A
Older Than Dirt
el ess A's Avatar
You still have another issue of the ZL1 hood lines not matching up with either of those. The LS hood lines would be too narrow and the SS hood lines would be too wide. Again, unless you used a ZL1 hood or modified the hood lines. But it should work. I say should. Not sure about the wiring part. Ofer would know.
