Old 07-25-2009, 07:24 PM   #1
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
swithing from Drive to Manual
Okay, here goes. I have and have had cars that have the ability to switch from full auto to manual mode. THE QUESTION I HAVE, is can you switch from Drive to Manual mode ON THE FLY? I have the manual, and have read it cover to cover, especially section 8, pages 26 thru 29 which is all about the auto tranny. BUT it never states that you can switch from one mode to the other ON THE FLY. Does anybody know FOR SURE? one of our TURE GM GUYS??
Old 07-25-2009, 07:30 PM   #2
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
Yes it does and vice verso.
RickRay is offline   Reply With Quote
Old 07-25-2009, 07:33 PM   #3
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
Mmhmm.
2023 GMC Canyon Elevation
Old 07-25-2009, 08:49 PM   #4
Spyderseal
Spyderseal's Avatar
Drives: 2010 SS (Sold)
Yes it can. I test drove one the other day and my dealer specifically told me to do it on the fly so I could see that it can be done.
Spyderseal is offline   Reply With Quote
Old 07-25-2009, 10:10 PM   #5
NUCAR
Drives: 68 big block
Okay, here goes. I have and have had cars that have the ability to switch from full auto to manual mode. THE QUESTION I HAVE, is can you switch from Drive to Manual mode ON THE FLY? I have the manual, and have read it cover to cover, especially section 8, pages 26 thru 29 which is all about thye auto tranny. BUT it never states that you can switch from one mode to the other ON THE FLY. Does anybody know FOR SURE? one of our TURE GM GUYS??
Switching to M will first put it in the Sport shift mode where it will still shift automatically but with a "sportier" shift algorhythm. Touching a tap shift button on the wheel will give you a gear indication in the center DIC at the lower left. Down shifts will rev match to avoid the car lurching on a down shift. The car will keep you from doing anything that will hurt it.
NUCAR is offline   Reply With Quote
Old 07-25-2009, 10:35 PM   #6
rocketman 12
SOON.........
rocketman 12's Avatar
Drives: 2010 ABM SS/RS Z-281LE
what he said^^^^^^^ the one I just rented had that, I messed with it a couple of times, personally I don't really like it......
No, it's not a real Z/28.....
rocketman 12 is offline   Reply With Quote
Old 07-26-2009, 01:32 AM   #7
BrandonGoodman
BrandonGoodman's Avatar
Drives: 2010 1LT RS Camaro
You can definitely shift in and out of manual mode at anytime
2010 1LT RS Victory Red
event code 1100 7/4/2009
ORDER CANCELLED
7/18/09 bought it off another dealer's lot
Prior:
1984 305 Camaro
1997 5.7L Z28 Camaro
BrandonGoodman is offline   Reply With Quote
Old 07-26-2009, 06:07 AM   #8
Sir Nuke
Sir Nuke's Avatar
Thanks Guys, that clears it up for me!
Old 08-12-2009, 11:56 PM   #9
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
Switching from Tap Shift back to normal Sport Mode
Ok, here's a question...I know you can shift back and forth from "D" to "M" on-the-fly. But once you've used either tap shifter in "M" mode, the tranny stays that way until you shift to "D" and then back to "M," correct? Or is there another way to get back to regular "M" mode after tap shifting that I'm not aware of?
I've been wondering about this because sometimes I like to shift down for that burst of power...but then I'm done and just want to immediately go back to regular "M" mode. Don't really want to shift to "D" and back to "M." I guess that will become second nature after a short while, though, eh?
Any thoughts out there...?
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 08-13-2009, 11:37 AM   #10
BrandonGoodman
It will stay in "D" or "M" until you physically shift it from one position or the other. These are physical locations on the console shifter. The shifter will never move on its own. There are however circumstances when in "M" mode when it will auto shift gears for you. I haven't fooled around with that enough to remember specifics but I believe that is kind of a failsafe functionality to keep you from over revving a gear.
ORDER CANCELLED
Prior:
1984 305 Camaro
Old 08-13-2009, 11:41 AM   #11
FenwickHockey65
If you leave it in M without shifting, it goes into "Sport Mode."
Old 08-13-2009, 11:42 AM   #12
BrianGriffin78
BrianGriffin78's Avatar
Drives: 2009 GMC Yukon
Yes, you can you go into a sports mode and it will give you an extra burst. It is the edge the Auto has, that it can go into a manual mode while on the fly. Really gives a nice performance.
BrianGriffin78 is offline   Reply With Quote
Old 08-13-2009, 11:44 AM   #13
BrianGriffin78
What's good about that you get the manual feel almost identical, but don't have to worry about stalling the computer will just put you back in the last shift. With a manual you will stall and could hurt the car.
Old 08-13-2009, 11:49 AM   #14
BrandonGoodman
I'm definitely going to have to play with this M mode some more. Seems I made a couple bad assumptions about it. How many of you guys just drive it in M mode all the time without tap-shifting?
I apologize for any misleading comments.
ORDER CANCELLED
Prior:
1984 305 Camaro
Did you go with Manual or Auto? Age? Mayhem V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 493 07-16-2015 09:10 PM
Tips on Driving a Manual Trans Zabo General Automotive + Other Cars Discussion 23 01-14-2013 04:35 AM
C&D Test Drive of new BMW M3 LSxcellent General Automotive + Other Cars Discussion 5 10-15-2010 02:00 AM
Help! Manual or Auto? mikeyp15 5th Gen Camaro SS LS LT General Discussions 25 05-17-2009 01:34 PM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 06:11 AM
