Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 02-20-2014, 06:14 PM   #1
JB12ZL1
Drives: victory red Camaro ZL1
square set up ZL1
not sure if this has been answered anywhere...but can I run 295/35/20 on all four corners on my Zl1!
JB12ZL1 is offline   Reply With Quote
Old 02-20-2014, 07:46 PM   #2
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
Yes or you can run 285's all around like 1LE. But the ZL1 suspension has been tuned for the factory staggered tire sizes.
CamaroTom is offline   Reply With Quote
Old 02-20-2014, 09:49 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I have aftermarket wheels for the road course that I run 285/35-20 square which have a compromise offset of +30mm. Stock fronts are +23 and stock backs are +37. They seem to work great! I can rotate them front to rear only since the tires are directional but it helps!
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 02-22-2014, 01:17 PM   #4
RajunCajun
Drives: 2013 1SS
How can you rotate with the wheels are 10" and 11" wide?
RajunCajun is offline   Reply With Quote
Old 02-22-2014, 01:43 PM   #5
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
shibbs is offline   Reply With Quote
Old 02-22-2014, 01:49 PM   #6
RajunCajun
Drives: 2013 1SS
I had this question for the dealer that said "they were going to rotate my tires". I didn't ask because I didn't want to get pissed after hear lies! I do speak french when I get pissed!
Old 02-23-2014, 03:30 AM   #7
shibbs
Captain Gingerbeard
shibbs's Avatar
PLUS they're asymmetric AND directional.
Old 02-26-2014, 12:17 PM   #8
danvillekidd
2013 ZL1
danvillekidd's Avatar
Drives: 2013 ZL1 m6
Has anyone tried fitting the 305s up front on the stock wheels to create a semi square setup that way? Have looked a few times and not found anything mentioning it.
danvillekidd is offline   Reply With Quote
Old 02-26-2014, 01:48 PM   #9
shibbs
Captain Gingerbeard
shibbs's Avatar
Pretty sure that people have run into fitment issues with this - the tire rubs on the strut. I don't think it'll work.
Old 03-02-2014, 02:23 PM   #10
Logan1234
Drives: 2014 ZL1
Right to left and left to right.
Logan1234 is offline   Reply With Quote
Old 03-02-2014, 11:28 PM   #11
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Actually, if you dismount the tire on the rim you can rotate left to right. I do this because my dominant tract direction wears the tires on the right side of the car a lot faster than the left.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 03-03-2014, 06:16 AM   #12
Stephen12ZL1
Drives: '21 ZLE A10
sure...good point.
